Sky InsuranceEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Like Tree4Likes
Thread: Car problems after re-map! HELP!!
    Harveysmith's Avatar
    Oct 2013
    86
    Ok so I have just had my s3 8p remapped and for the first day it was beautiful, smooth all way up to redline. Second day I took it out for a spin and again beautiful at low revs but when I put my foot down and the car got to around 5000rpm the power just died! The whole car jults and the revs return to normal. It's as if the car runs out of fuel at 5000rpm and above. Again the car is fine through te gears and even when you floor it it's nice up to 5000rpm then dies and returns to normal!
    I have aves spoken to the guy who remapped it and he said it was a common problem on the 1.8T previous but never heard of it in the 2.0l 8p!
    Any ideas???
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,198
    happened to my a3, had to get the map readjusted.
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Jan 2012
    458
    Check / change your plugs - they tend not to last more than 10k.
    NHN likes this.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    As nluk100 says,check/replace the plugs first.
    After that,coil packs are another weak point.
    Which company did you use,and what software?
    Oct 2013
    86
    Quote Originally Posted by S3Alex View Post
    I used a local tuning garage and they are Quantum remap dealers. He has said it might be the turbo pipe collapsing?
    is that a possibility?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Quote Originally Posted by Harveysmith View Post
    It's remotely possible,but frankly unlikely.
    I've not seen that happen,even on mine.
    More likely are the two things above,and what he should do is to log the car under the conditions that are causing the problem.
    Fuelling is another possibility,but logging will show that also.
    27,007
    IMHO I would say its not the intake pipe collapsing on the 8P 2.0, that was the 1.8t for sure that Forge created the new one for, very well known issue of which I had myself.
    I would also say plugs, coils then map tbh as above, 1st 2 are common as mud.
    Oct 2013
    86
    Great thanks guys. When you say loggin AlexS3 do you mean when you plug the car in for diagnostics?
    Will that show spark or could issues?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Plug it into a laptop and take it for a drive whilst collecting data.
    Then review data such as boost fuelling timing etc etc and any fault codes.
    Audi-Rog's Avatar
    "Fire up the Quattro!"
    Dec 2009
    Milton Keynes, United Kingdom
    168
    Add Audi-Rog on Facebook
    Sounds like a camshaft sensor/engine speed sensor fault.
    I had it recently on my VRS. Changed the sensor and all is well.
    As said, best get the car scanned to be sure.
    |Audi S4 B6 4.2 V8..gone|A3 TFSI Q S line..gone|
    |Current: Audi A3 3.2 V6 DSG
    S line|BBS Carlitos|
    |K&N Panel Filter|Superchipped 265 BHP|
    |Link
    :FREEMAN:detailing Milton Keynes|
    Oct 2013
    86
    Booked back into the garage for Monday. Will mention all your comments. Thanks guys
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Good luck.
    Don't accept it until it's running perfectly,and they do need to log it.
    Oct 2013
    86
    If the issue is mechanical is that garages problem to sort out or mine? Don't know where I stand really with that?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    I think that software and map related issues would be their responsibility,but things like plugs,coilpacks etc and any issues exposed by the map would be yours
    Oct 2013
    86
    Hi all, me again! Sorry to be a pain. As I said in a previous thread I changed the coilpack and the sparks and all seemed to be ok! SEEMED! Took it out for a spin today and guess what...it's happening again!!! Ahhhhhh! They have turned the map down and reduced the boost, logged the car and the following results shown....
    P1093 = Bank 1 fuel measuring system 2 malfunction
    P000A = Camshaft position slow response
    P0087 = fuel rail/system pressure to low
    P2261 = Turbo boost pressure not detected
    Any ideas!
    Thing is I don't want to just change any probability costing £££££
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    635
    How long have you had the car?
    Did it run ok before the map?
    Can they flash the car to standard to see if the car runs ok without the map?
    Looking at your faults I'd be suspecting the map if it ran ok beforehand.
    Oct 2013
    86
    Yeah they said they can flash the map and return it to standard. I have had the car for around 6 months and it was not doing it b4 the map. Quantum are adamant that it's not a software issue as the faults don't relate to software issue. I am toted to change the camshaft sensor and the fuel sensor to see if that stops it. But again it's just £££. Not really sure what to do. Just remove it?
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    635
    I think most of those codes look software related.
    Get them to put it to stock and if the problem persists then change things.
    If it ran ok for months before the map I'm sure it'll run fine once put to standard.
    IBIS WHITE S3
    Revo stage 2+ and loving it
    manor13's Avatar
    Aug 2013
    West of Lothian
    422
    I would take it off personally, not a vcds person but logs are related to the fuel pump maybe which on stage one you shouldn't need to change. Did they scan the car before mapping it?
    Any tuner should have done that so if not remove map and clear and scan the car for fault codes. some of the more experienced guys may know better as everyone seems to have different ideas on what are the "Stages" good luck though.
    p.s what fuel are you using the good stuff or supermarket stuff
    2006 8P Audi A3 2.0 TFSI Quattro Sportback SE / 2013 8V Audi A3 1.6 TDI Sportback
    Oct 2013
    86
    Supermarket stuff but my m8 gave me a good ear full and now running bp 97. I am almost convinced that it might be the DV. I took it for a spin again earlier and worked fine, floored it and it pulled all the way. On my way home I put my foot down going up a steep hill and guess what....it happened.... Then again going up the next hill. As soon as was on straight it worked. Makes me think pulling the car up the hill with so much boost is blowing the DV valve and stopping power.
    Back in the garage tomorrow with a different garage on a rolling road to determine the issue...hopefully
    sliced's Avatar
    Jun 2012
    1,198
    have you got the garage to return the car back to stock first to 100% make sure its not the map?
    Oct 2013
    86
    No they haven't done that yet. He sent the file back to Quantum and they check the file and fault codes and Quantum have said that the file/map is absolutely fine. They sent back a second map that had the boost turned down.
    I'll be honest, if they can't find any issues tomorrow I will just have Car flashed, get my money back. Just annoying
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Seriously,there has to be a reason for the way the car is behaving.
    If you can get most S3's running Stg2+ software and 360bhp without issues,there is clearly a problem here.
    I'd be tempted to have it removed,get your money back,and take it to a tuner that CAN solve the problem.
    sliced's Avatar
    Jun 2012
    1,198
    yea might be best to get it get your original software back on there.
    Sounds a bit like fuel cuts stage 2 gti's experience...
    Oct 2013
    86
    This has turned into a massive nightmare! The car has been in the garage since Tuesday. The ECU has been flashed back to standard and After sticking it on the rolling road the same fault codes showed
    P1903
    P000A
    P0087
    P2261
    They the. Suspected it was the DV valve. So after replacing it with the updated Audi one fitted to the RS models.Then they stick it back on the rolling road and it happened again. He said it's working a lot better now and revving higher but still cutting out. They logged it and now all error codes have gone except 1 P1903 = bank 1 fuel measuring system 2 malfunction!!
    now they are completely stumped! The mechanic seems to think its still the map and it might be lingering or mesas the ECU up.
    Is this possible? The only way to make sure for good is to get Audi to put the original software back on but don't know of they would do that??
    Does anyone have any experience or advice with the above fault code?
    Not sure what to do now
    Audi-Rog's Avatar
    Dec 2009
    168
    I still think you need to change/check the camshaft sensor, with the symptoms your are having, they would lead me to that. I changed the cam follower, fuel filter and checked the DV, but still did it. Changed the camshaft sensor and fixed it straight away. It's £120, but cheaper than some of the other options.
    Rog
    |Link
  28. #27
    Oct 2013
    86
    Ok cheers Rog, will mention that to the garage.
  29. #28
    Oct 2013
    86
    Is the camshaft sensor the same as the camshaft position sensor as that's all I can find?
  30. #29
    Audi-Rog's Avatar
    Dec 2009
    168
    Yes mate
    It's also known as the engine speed sensor.
    Rog
    |Link
  31. #30
    Oct 2013
    86
    Hi Rog
    Sorry to be a pain. Do you know what one I need as there are 2
    genuine audi s3 camshaft sensor | eBay
  32. #31
    Audi-Rog's Avatar
    Dec 2009
    168
    Hi Harvey,
    What I think you need is this, Camshaft/Crankshaft position sensor.
    Link below
    Audi | Euro Car Parts UK’s No.1 Car Parts Retailer
    I wouldn't trust the ones on eBay, you better off going to TPS or a dealer for the genuine part. Not cheap, but worth it.
    Having said that, the one on ECP looks ok.
    The Audi part number I used is :06A 906 433L
    There is some confusion, as the part name seems to change from place to place!
    But this is what I had changed and it sorted the problem. I hope it does for you mate.
    You may want to double check the part number for the S3, it maybe different?
    HTH
    Rog
    |Link
  33. #32
    Oct 2013
    86
    Ideal thanks. Bit of a learning curve for me.
  34. #33
    Audi-Rog's Avatar
    Dec 2009
    168
    No problem. It was a learning curve for me too!
    I hope it sorts it for you.
    Check this thread out too, it may help.
    S3 wont rev past 4.5k Revs Help!!!!!
    |Link
  35. #34
    Oct 2013
    86
    Changed the camshaft sensor.....still having issues!!! Another brick wall
  36. #35
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Sorry to hear that.
    You do need a tuner who can just work the problem until it's solved.
    AMDTuning spent a lot of time tracking down a very odd fault on mine and along the way found a dirty MAF,faulty thermostat and a couple of other bits before the final issue was a faulty throttle body.
    Often,it's not just one thing.
  37. #36
    Audi-Rog's Avatar
    Dec 2009
    168
    Sorry that didn't work out, They did change the correct sensor, didn't they? It's the Crankshaft sensor, not camshaft. Located under the engine, next to the oil filter? It's a pig to get at!
    You may want to confirm that they did the right sensor.
    If they have, then I'm stumped to be honest, what it could be.
    Rog
    |Link
  38. #37
    Oct 2013
    86
    Just an update guys...still no car, checked evey possibility and no sick luck. Finally sent it to Audi and again throwing no fault codes no but they seem to think its a cambelt timing issue!(Only recently had it done buy the previous owner) What ever that is! The quest goes on
  39. #38
    Mar 2014
    38
    What was the outcome of this problem? Did you get the issue sorted?
  40. #39
    Oct 2013
    86
    Hi
    It was a simple crank shaft sensor
    S3Alex likes this.
  41. #40
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Hi
    Good result.
    Does show however that these engines are pigs to sort if one simple sensor decides to chuck in the towel.
  1. Please help!....over rev problems after re-map on 2006 s-line 2.0L tdi 170
    By Chiefnutter in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2013, 15:24
  2. Replies: 0
    Last Post: 25th August 2010, 14:32
  3. S3 Help needed after re-map
    By R55_SND in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2009, 15:41
  4. Please Help... Problem after service - Engine Warnign Light
    By bl_1969 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2008, 17:45
  5. CHIP POLL/CAR PROBLEMS AFTER CHIPPING - CAST YOUR VOTE?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2005, 21:06
