Sky InsuranceVolks Autos
Results 1 to 9 of 9
    Dec 2013
    7
    help 2007 A3 Radio Aux Install questions...
    Hello
    I bought a Aux vw kit for my audi a3 radio... however it only works if you have the plug for the cd changer...
    My radio has the built in cd changer, bluetooth , steering wheel controls and Tape deck (yuck)
    When i took the radio out i found this mystery blue wire... could i somehow tap into that?
    if not what options do i have to retain blue tooth..ect
    i dont want to use a tape adaptor
    thanks
    Greg
    27,029
    That is a connector for your console switch pack, someone has either unplugged from one of the console buttons like esp etc or it was fitted from factory & left unplugged due to a system not being fitted.
    Which connector type has your aux kit got?
    Mar 2011
    Cleveland
    965
    Doesn't the aux plug go into the bottom socket (red/orange plug) if it's empty? You then press the CD button twice to access it. It replaces an external CD changer.
    Dec 2013
    7
    The plug I have is this
    Dec 2013
    7
    27,029
    You can buy 2 kits, 1 is iso like your radio connections & other is quadlock which is useless to you, normally the aux iso has an adapter or pins to push into the holes of existing connector.
    Dec 2013
    7
    Any links to the right kit for mine?
    Dec 2013
    7
    Dec 2013
    7
    Quote Originally Posted by gskills View Post
    bump for anyone who knows what he is talking about... ie the radio connectors and what i would need..
    thanks
  1. Help please. A4 vert 3.0 question.
    By Chad! in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th December 2009, 17:49
  2. AUX-IN QUESTIONS...
    By HSerce in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2009, 18:06
  3. Aux in question
    By A3simon in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th August 2009, 11:16
  4. RNS-E install question
    By Sinny71 in forum In-Car Entertainment
    Last Post: 13th February 2007, 09:33
  5. Newbie Needs Help: tires and radio
    By upinarms in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2004, 06:39
