JMB RetrofitsBadger5
Thread: cruise control
    Sep 2009
    HORWICH,BOLTON
    35
    cruise control
    Please could anyone give me guidance on fitting cruise control .I have a a3 tdi sport back 2005.(with an onboard computer)
    I've just rung Audi (Bolton). I gave them my reg number and they said I would need a new steering module as mine is not compatible. Would they be correct or would they be guessing?
    27,121
    Only way to know 100% is to check with vcds, although if you have a dis then it should be possible to fit.
    Sep 2009
    HORWICH,BOLTON
    35
    Using vcds what would i look under?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,110
    Mate, if you already have an on board computer with trip stalk, then you 100% have the correct module.
    Dealers know jack and don't have no real knowledge. Even if you had a MFSW, they would still have said you still need a new module.
    Chances are high you have the AH module which is totatally fine.
    But if you want to check with VCDS for peace of mind, check the P/N in steering module 16. It should begin 1K0 and end AH if you currently just have trip.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  1. cruise control retro-fit
    By yoda01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2010, 15:11
  2. CRUISE CONTROL, CAN IT BE DONE?
    By blackwood in forum General Technical / How To
    Last Post: 2nd October 2004, 15:20
  3. Retro fitting cruise control
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2004, 10:35
  4. Cruise Control,
    By t955daytona in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:45
  5. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
