Chris NottMonster Motorsport
Like Tree1Likes
  • 1 Post By NHN
Thread: 2008 S3. Cold engine, intermittent squeak when ticking over.
    Jan 2014
    Hope fully someone is in the know with this one, any ideas?
    When engine is cold and turned on ticking over there is a squeak that is coming from the engine bay.
    It does stop after a while but to be honest only a couple of times its been sat ticking over for any amount of time for that to happen.
    Jono
    26,777
    Welcome to the site.
    Maybe a belt/pulley combo, had the same myself, not to say its the same issue yourself, but I know I changed an aux belt for someone & it cured an almighty annoying squeaking noisy, try temp removing the aux belt & see if on startup it is still present.
    jono2908 likes this.
  1. metalic rattle squeak when let of accel intermittent?
    By justarn in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2013, 18:43
  2. Engine squeaking when cold
    By Gavlar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2011, 17:00
  3. '05 S4 Frustrating Engine Whine - only when cold......HELP!
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th February 2010, 20:07
  4. Squeak when I start the car
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2007, 13:13
  5. Engine speed drop when using electrics
    By Rich in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2007, 16:09
