JMB RetrofitsVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 54
Like Tree8Likes
Thread: Why does my car sometimes beep at me when I turn the ignition on?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    As the title says...Why does my car sometimes beep at me when I turn the ignition on?
    It's the same or similar beep that you get if your car needs a service or if you need fuel, and I need neither of these.
    It happens quite a lot but not every time I switch it on.
    VCDS says no problems at all, so I don't get it
    Any ideas?
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jan 2012
    101
    Seatbelt warning?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by Smeds View Post
    Seatbelt warning?
    Nope, definately not that as when I do have that I have a warning symbol on the cluster and a beep every 5 seconds or so.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    DPF, used to always do it on my 58 170 diesel.
    If your really quick you can just see flicker of an orange exhaust.
    Often did it on mine, think it's just the shuffling of power to certain modules/sensors as you crank that in gives a false problem briefly.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by mjr901 View Post
    Ah ok, thanks. So nothing to worry about? I assume not as i'd hope to be getting some errors in the VCDS log if there were problems.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by A3Kent View Post
    Used the wind me up a bit lol. I had no errors stored either. I had my car from 6k-33k and it always did it frequently. Never had a problem with the DPF either.
    Pretty sure you can measure the level of soot in a DPF anyway, so if your losing sleep over it, get it forced for a regen and see how you go.
    Or the beep could be due to low outside temperature.
    Or the beep could be for something I haven't come across yet.
    Personally I'd leave it and wouldn't worry.
    A3Kent likes this.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Nothing on the DIS?
    Mine beeped and the coolant symbol was on, quick scrape of the prongs in the bottle with a screwdriver and it's fine.
    Growing old is mandatory, growing up is optional
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by LEE69 View Post
    Nothing on the DIS?
    Nope, just a single beep when I turn the key, not even when the engine is on. As mjr901 says, must be the DPF.
    I'll live with it I guess
    Feb 2012
    331
    Mine does this beep too, but the DIS usually says passenger airbag on ??
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by Sayam View Post
    It gives you the false sense that it's beeping at you for the airbag, as that always comes up anyway.
    As I said, I remember catching a glimpse of the DPF light when it beeped on one of the many occasions, that doesn't necessarily mean that's the beep..I'm merely assuming, as no faults showing and that light was apparent briefly (a blink of an eye) on seperate occasions only on start up that it could be the DPF.
    Andy1608's Avatar
    Nov 2013
    York
    518
    Visit Andy1608's Youtube Channel
    Always fuel that's beeping at me lol
    Jan 2013
    Edinburgh, Scotland
    61
    Mines beeped every so often when the battery was getting close to shot, think it flashed up as an ESP fault IIRC.
    Was only the once I was paying attention and managed to see it flash up. Hasn't done it since battery was replaced!
    Mar 2013
    78
    Quote Originally Posted by weeroughy View Post
    Thats good to know, mine often beeps with no error message, but over the last week it beeps almost on every start up! No error messages normally apart from the ESP fault above which caught my eye but disappeared before I could read it and a false error on my rear driver brake light being out which it isnt!
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Yes and this was apparent too!!! just remembered that one!
    XFi
    Jun 2010
    344
    If the temp is 5C or below it beeps once, I only found this out recently after wondering what it was also!
    Boydie likes this.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    low battery is 3 beeps
    could be the temp beep did it do it in the warm weather ?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Definitely not the temp in my case. It did it this morning and it was fairly mild for a winter morning.
    c_w
    1,061
    Mine does this and always has done on and off, perhaps every 1 in 15 starts, it seems to be done when starting the car quickly, like when getting in and starting immediately without the glow plug light going off. Mine is a 170 too but I don't think it's anything to do with that. I'm sure I sometimes get a glimpse of "ESP fault" but it is not recorded and only ever does it on ignition turn on.
    27,097
    Quote Originally Posted by c_w View Post
    Interesting as that's usually the A4 that does this.
    Jan 2013
    Edinburgh, Scotland
    61
    Mines was only one beep and hasn't returned since the battery was replaced?
    Exactly what mines did, flashed up ESP fault and disappeared almost immediately!
    Aug 2013
    Surrey
    135
    My s3 has Esp fault/see handbook as it turns over but as it starts running its fine.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Quote Originally Posted by Granta View Post
    Mine did this until i swapped the battery for a new one, last one had just started to be a bit laggy.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Quote Originally Posted by XFi View Post
    I will have to remember that next time my S3 does it. Would happen every now and again and I thought it was just a ghost fault from starting the engine too quickly??? :S
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Mine is a 170 and does exactly the same thing. ESP fault flash and beep every now and again.
    Sometimes it takes a little bit longer to start as well. Always starts first time but just another second or two.
    Wonder if my battery is on the way out as i've never changed it.
    Would it do any harm by trickle charging the battery rather than getting a new one?
    LEE69 likes this.
    Nov 2013
    Suffolk
    47
    Add cnahamilton on Facebook
    My 2007 S3 does this too. Not very often though! I did manage to catch the message the last time it did it and is just said 'see owners handbook' but didnt say why I need to lol.
    c_w
    1,061
    Glad it's not just my car then lol. Perhaps that system is very voltage sensitive and the starter drain triggers it momentarily? I changed the battery a few months ago and now thinking about it can't recall if it's done it since...
    LEE69 likes this.
  28. #27
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Quote Originally Posted by Djwoody View Post
    No trickle charging be ok
  29. #28
    Nov 2013
    Suffolk
    47
    I find if I jump in put the key and turn it on straight away it will beep and show the message but if I get in put the key in and turn it as far as getting all cluster lights on, wait a second and then start, it won't beep at me.
  30. #29
    Oct 2012
    139
    Mine used to do it from time to time. Hasn't done it since I replaced the battery about 9 months ago.
  31. #30
    c_w
    1,061
    Quote Originally Posted by cnahamilton View Post
    That's my findings too, it doesn't like being rushed in the morning lol
  32. #31
    Feb 2013
    41
    I had to replace my battery last Winter as it kept flashing ESP fault when I turned the ignition on.
    Took it to the garage, they put a battery tester on it and it was 1/10 on the reader, so it was ****ed. Luckily an easy fix though.
  33. #32
    Oct 2012
    SW London
    16
    I agree, my 2010 A3 (tdi 170) beeps whenever i rush it. Never happens if i wait for all warning lights to go out before starting the engine.
    Not noticed a light or warning message when it beeps though...
  34. #33
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    How much is a battery roughly for the A3 170?
    2008 Audi A4 B8 3.0TDI Quattro S-line (240) in Aruba Blue
  35. #34
    Apr 2009
    63
    My battery was about £ 95. A bosch heavy duty one. Sorry I dont know what its called.
    My 170 used to do the esp thing too giving it an extra second or so helped.
    Audi assist checked my batt and said ok but changed it anyway.
    It now hits me with reversing lights out and sidelights complete with lamp signals.
    Problem is there all ok. Annoying.
    2008 sline sportback 2.0 tdi stronic 170
    brilliant black, rnse ,full heated electric leather seats, privacy glass, auto and lighting packs
    adaptive xenons,
  36. #35
    Oct 2012
    139
    You want a Varta Silver Dynamic Battery (seems to be the battery of choice on here). Think mine was about 70 quid delivered.
    Easy job to do as well. Biggest pain is taking the old one down to the dump for recycling.
  37. #36
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Which capacity is it? On the Varta website they have 77Ah, 80Ah or 85Ah
  38. #37
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,093
    Quote Originally Posted by t3ddy View Post
    Mine does the same. If you jump in and start it, it will bleep.
    Haven't seen any warning lights or messages.
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
  39. #38
    Neale_hardie's Avatar
    Sep 2013
    Elgin, Scotland
    20
    My 170 has just started doing this "beep" when you start up with "ESP system failure" also gonna take the battery out get it on charge then get it tested to see if any faults found.
  40. #39
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,093
    Quote Originally Posted by Phil-1 View Post
    I have a newish battery and it still bleeps, saying that it hasn't bleeped all weekend
  41. #40
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,093
    Did a test this morning. The car only bleeped when the outside temperature was under 4C.
    Could it be some sort of warning?
  1. Why does my car every now and again start screaming?!
    By wolfy1988 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2011, 11:32
  2. Why does my car use so much oil!??
    By HenriEST in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th April 2010, 11:45
  3. Why does the car turns off when...
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2008, 17:32
  4. Why does it feel my car is breathing through a sock?!
    By denzelburner in forum Diesel forum
    Last Post: 25th January 2008, 01:26
  5. why does my car go forward when I select reverse???!!!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2007, 02:22
