Chris NottVolks Autos
    Aug 2012
    7
    Xenon headlight problem
    Evening,
    Earlier today I went to go out in the car but it wouldnt start, an hour later I went to see if it would start and it did....anyway.....went out tonight in the car and my drivers headlight dipped beam is not self levelling.
    When the car starts the left light goes through the check but the right does not (not that I can tell anyway). No dash warning lights shown up and dont have anything to scan the car with.
    Tried searching but never found an answer that reflects my issue of one light not self levelling.
    Any thoughts guys and girls?
    Aug 2012
    7
    Quick update.
    Used the car yesterday morning and the light was still not self levelling but when I went home from work both lights were self levelling.
    Could the battery be on its way out causing this to happen as this only started when the car failed to start?
    Either way am happy my lights are working again as normal.
    Dec 2011
    41
    Sounds like a loose sensor, had the same issue on my older a3. new sensor is about £60 off ebay mate
  1. XENON HEADLIGHT FLASHING PROBLEM
    By jusw in forum General Technical / How To
    Last Post: 23rd December 2010, 15:59
  2. xenon headlight problem
    By tominski in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2007, 11:25
  3. wandering xenon headlight - any ideas whats wrong
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2003, 13:10
  4. Xenon Headlights - 7 fix for a 680 headlight!
    By Patrick in forum Classic Audi Forum
    Last Post: 12th October 2003, 17:16
  5. Xenon Headlights
    By wascal in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2003, 21:43
