Chris NottVolks Autos
Results 1 to 16 of 16
    Nov 2012
    123
    cold start issue. 2 or 3 beeps and radio turns off!
    Car is a 2.0 TDI 2004 119000 miles.
    A handfull of times on cold starts my car has hesitated to start and gave me 2/3 beeps (the sound it makes when you need to fill up with fuel). Also if the radio is on it turns off and I have to turn it back on.
    I do notice that the glow plug light stays on until it starts and also the dash lights dim a bit.
    So I am thinking either battery or glow plugs? Does that sound about right or am I barking up the wrong tree?
    Nov 2012
    123
    Is it normal for the car to give warning beep noises other than for low fuel?
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    571
    Sounds like either like you say, battery or glow plugs. Does it start okay when the engine is warm?
    Nov 2013
    Heath Hayes
    647
    Thats usually a sign the battery is on it's way out, If it's the original it's 10 years old so has done well. I would go for Bosch or Varta , It's not worth buying a cheapie and saving £10. You can get them cheap enough off Flea bay or carparts4less .
    Karl.
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    398
    My last Golf tdi done this about 2 weeks before the battery went.
    Its a sign of low voltage and things shutting down with low voltage on cranking.
    As above buy a battery before it lets you down.
    IBIS WHITE S3
    Revo stage 1, Loba Hpfp
    Nov 2012
    123
    Cheers guys. Would someone please send me a link to the correct battery so I don't get the wrong one. A member on here is scanning my car next Saturday so will see if that brings anything up.
    Apr 2012
    UK, Portsmouth
    571
    The battery I have in mine, however I got mine from Halfords.
    Bosch Audi S5 Battery 096 5 Year Guarantee | Euro Car Parts UK’s No.1 Car Parts Retailer
    Nov 2012
    123
    Ok this might seem a daft question but what is the difference between all these batterys? Just looking and some Bosch ones are 60, 70, 80 or the one you have posted for 120. Normally just get a cheap one out in and it works.
    Apr 2012
    UK, Portsmouth
    571
    Quote Originally Posted by heap1000 View Post
    With batteries you need to look further into them than the price, for example..
    77 amp hours, 780 CCA (cold cranking Amp) with a 5 year warranty for the £120 Bosch battery.
    60 amp hours, 480 CCA (cold cranking Amp) with a 3 year warrenty for the £66 Lion battery.
    Basically, a modern diesel needs a large battery to just turn it over and not taking into account all the electrics on a modern car such as heated seats etc.
    amp hours is the amount of energy charge in a battery that will allow one ampere of current to flow for one hour, so higher the better.
    CCA is the amps the battery has at 0 degrees, bigger the better and more power at lower temperatures.
    Nov 2012
    123
    Well you learn something new every day! What would be a good mid range battery? Funds are a little low at the moment with Xmas plus I have it Booked in for a cam belt change on Tuesday.
    Apr 2012
    UK, Portsmouth
    571
    Stick with Bosch, but go for maybe the blue top S4 battery, £88.80? Still got a 4 year warranty. Try Halfords also, if you know someone with a trade card.
    Bosch Audi S4 Battery 027 4 Year Guarantee | Euro Car Parts UK’s No.1 Car Parts Retailer
    Nov 2012
    123
    Apr 2012
    UK, Portsmouth
    571
    Yeah, better than the battery from Eurocarparts
    Nov 2013
    Heath Hayes
    647
    This is the Varta equivalent of the Bosch battery. £64 delivered. You don't have to pay loads of money for a decent battery if you look around.
    VARTA E11 096 HEAVY DUTY 74Ah Car Battery | eBay
    If you want a slightly better battery with a 5yr warranty and a tad more performance £71 delivered. They are called Halfrauds for a reason .
    VARTA E44/096 SILVER 77AH 5 YEAR WARRANTY CAR BATTERY | eBay
    Karl.
    Nov 2012
    123
    Thanks Karl that is good to know.
    Apr 2012
    UK, Portsmouth
    571
    As Desertstorm said, Varta are also a good brand for batteries.
  1. Jet black fuel filter and minor cold start issue
    By the obese penguin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2013, 19:49
  2. Cold start issue
    By Connor_scotland in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2011, 10:02
  3. cold start issue tdi 130
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2011, 16:16
  4. Cold Start Issue......?
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2007, 14:48
  5. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
