Badger5AH Fabrications
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Pinch bolt on the hub to release the strut
    Basically what I am trying to find out is what took you use for this. The Americans call it a 14mm 12 point driver. Where can I get one in the uk or use in replacement
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Quote Originally Posted by Gavlar View Post
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    eBay - it's an M14 spline drive socket.
    You can get them from Halfords as well.
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Sweet wanted to double check. Thanks buddy
  1. wheel bolts and the void behind the hub??
    By crazypainter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th July 2012, 10:47
  2. Replies: 15
    Last Post: 8th February 2012, 14:24
  3. How many mm's or threads of the wheel bolts should go into the hubs (2001 s3)
    By hank3944 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2012, 09:42
  4. Advice on how to remove the top control arm pinch bolt..
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2006, 19:06
  5. Bolt size for the hub on a 1999 A4 Quattro Turbo
    By swsimon in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:56
