Chris NottEM Tuning
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Artimus
Thread: A3 2.0 litre TFSI purchase
    inw
    inw
    May 2007
    6
    Advice please, considering the purchase of a 2008 A3 2.0 litre TFSI with 48,000 miles could anyone give any tips.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,214
    Hi inw,
    Check this thread, may be useful as another member is also looking at the same kind of car.
    Advice for buying 2.0t ?
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    inw
    inw
    May 2007
    6
    Thanks for that sliced but was thinking more about the glitches eg. fuel pump cam follower as mentioned in the other post and also heard this engine can burn more oil than the others - not too bothered about the oil but need to know what possible failures there could be on the horizon at 48,000 miles.
    Ive
    sliced's Avatar
    Jun 2012
    1,214
    Hi mate, if you post a link of the car etc we can advise a bit better depending of specific spec/ engine code etc
    inw
    inw
    May 2007
    6
    Hi, don,t know the engine code yet but it is 08/58 A3 2.0 TFSI 3 door sport with 48,000 miles 1 owner (I don't even know if it is belt or chain) but having had my fingers burnt with a quatro V6 engine I am now very nervous about buying another Audi even though I have had 2 previous that were excellent.
    sliced's Avatar
    Jun 2012
    1,214
    Quote Originally Posted by inw View Post
    ahh okay, make sure the belt/chain has been replaced as it due in terms of age. In terms of 48k probably due a major service, so factor that in.
    The newer ones, chain driven, have had cases of timing chain tensioners failing, might be worth reading up about.
    inw
    inw
    May 2007
    6
    Not again!! timing chains they were the problem with my V6. How can I find out when they went from belt to chain and would it be best to go for the earlier engine with the belt. Sorry to go on a bit but I am trying to do the research before purchase this time instead of after.
    sliced's Avatar
    Jun 2012
    1,214
    Might just be an american thing tbh, but i did research it a bit before buying my a3. It was mainly a problem for mk6 gti's though, but did affect a3's.
    2.0T TSI Timing Chain Failure - RS WORX Tri-State's Premier European Repair & Performance Facility : RS WORX Tri-State's Premier European Repair & Performance Facility
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    Hi fellas, I found the following on Pistonheads a couple of months ago! it suggests that these cars have belts, not chains....
    I recently (well, around 6 months ago) bought a Leon of the same era/chassis- thanks to the part sharing around Volkswagen Group, most of the issues I was looking out for are equally applicable to the A3. It's a bit of a brain dump but hopefully some useful information there:
    ABS sensor module fault is a biggie. This has got cheaper over the years but is still a ~£400 fix. Seems to be very intermittent- some cars suffer repeated failures, some are fine and dandy on the original one. If it's not had one done it will probably be fine but worth keeping in mind.
    As Va1o already mentioned, timing chain stretch on the 3.2.
    The 2.0 FSI and 2.0 TFSI need new timing belts plus water pump and tensioners every ~60,000 or 4 years. This was originally 115,000 from memory but Audi/VAG issued a notice on this due to premature failures. Some sellers and a few dealers seem to think the original figure still applies- it's not worth arguing the toss with a seller who thinks this as there are plenty of other cars out there.
    Maintaining Haldex can be expensive; many sellers neglect the 20,000 mile services (alternating oil/oil and filter) which leads to mechanical failures. Think these were sold as "sealed for life", like most gearboxes sold as such they should be treated as anything but in reality.
    2.0 TFSI can suffer from high pressure fuel pump failures, either in the cam or in the follower. This is potentially engine destroying- the early one-piece cams were prone to failure due to a patchy manufacturing process- if one of these has survived 80,000 miles it's likely to be fine. The replacement two-piece cams were too hard and caused wear on the cam follower, leading to fluctuations in fuel pressure. Worth checking both cam and lobe for wear. The same issue may exist with the non-turbo 2.0 FSI but I don't know offhand.
    Original and revision diverter valves on the TFSI can fail due to being made of perishable rubber. This causes boost leaks and can result in a CEL and error code, plus associated drop in power. The later all-metal revision of the valve doesn't suffer from these problems though some people still prefer the earlier revisions because they're a bit noisier.
    Variable intake manifold tumble flaps on 2.0 FSI and TFSI can stick, this is particularly pronounced in cold weather. Usually isn't bad enough to trigger a CEL but can make for a bit of roughness or hesitancy on cold starts.
    Similarly, the PCV (Positive Crankcase Ventilation) valve can die. This results in a rough idle when cold and a bit of hesitancy at low revs, plus a drop in fuel economy and small drop in boost on the turbocharged models. Easy to identify (just pull the oil dipstick out on a running engine, if it splutters it's working fine, if not it's probably dead) and quite cheap to fix too.
    I'm 80% sure that my Leon is suffering from this.
    Even if it's not all 100% true for later models (September '08 on), it's certainly useful for consideration and further research. Think I read somewhere that some engine have both a Belt & Chain - but I'm not sure if that was for my wife's Polo which I had renewed in November?!?
    HTH.
    P.S: link to the original on PH, it's the 5th post down.
    sliced likes this.
    2009 A3 SB 2.0T DSG S line
    inw
    inw
    May 2007
    6
    Thanks for the help fellas, I will carry on with the research but it's a bit of a minefield - sometimes with conflicting info.
    Ive.
  1. 2.0 litre TFSI 2005 A4
    By paul20v in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th May 2013, 16:27
  2. 2.0 Litre TFSI - Knocking noise in head
    By Alex C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2013, 18:11
  3. New Purchase
    By lakey in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2004, 22:23
  4. S3 uses 1 litre of Oil every 1000 miles
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2004, 13:14
  5. A4 Purchase
    By sillygreenaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd July 2003, 13:57
