Chris NottVolks Autos
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By A3_sline
Thread: Need help asap not locking windows not going up..
    Dec 2013
    16
    Hi
    Firstly id like to say sorry if repost or in. The wrong section i have an audi a3 sportback 2006 the central locking and windows playing up the door lock fine with key in the door and all the windows not going up or down need help asap
    Jan 2012
    SW London
    751
    u tried holding the key to the left when ur locking with the key? this normally engages global closure (close all windows).
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Dec 2013
    16
    Yeah done that no luck :-/
    John ler likes this.
    Oct 2013
    290
    Its probably a fuse, had this problem on a bmw I owned recently, take it to Halfords tomorrow, they fixed mine for the price of the fuse, £2.30 !
    Dec 2013
    16
    To be honest doubt can be a fuse as it sometimes decide to work 😏
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    Hi mate,
    The harness at the drivers door hinge may have broken wires or may just be loose at the connector! Pull the rubber boot back and inspect the loom.
    2009 A3 SB 2.0T DSG S line
    Dec 2011
    MIDLANDS
    241
    Quote Originally Posted by Artimus View Post
    Hi mate,
    +1 this seems to be quite a common problem.
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    Dec 2013
    16
    Had a look at that it seems alright? Also got another problem hazad lights keep going off not much joy with car not happy
    Dec 2011
    MIDLANDS
    241
    Have you got a multimeter to hand to test continuity of all cables that run through the door hinge rubber? They may look ok but could be broken inside the cable insulation.
    Not sure about the hazard lights - is the switch faulty?
    Dec 2013
    16
    If the wires were damaged will the windows work sometimes. Also when windows not working cemtral locking of keypad dont work? And for the hazads the switch works fine
    Dec 2013
    16
    Hi all
    Got it checked with multi meter wires seem all alright took door card of 1 of the module there was showing no sign of life also have fault P0600
    Dec 2013
    16
    Up date for the window and locking problem been told can be the comfort control module?
    Dec 2013
    16
    Problem solved thanks for all the help
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    what was it in the end mate?
    Dec 2013
    16
    Ccm module mate👍
    Artimus likes this.
  1. No central locking, windows not working and alarm constantly going off?????????
    By a3 quattr0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2011, 18:54
  2. Guyss A friend needs help ASAP
    By Azizur_Rahman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2010, 00:14
  3. i need help asap
    By chris1988brown in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 22:31
  4. NEED HELP ASAP
    By Andywilliams1977 in forum General Technical / How To
    Last Post: 31st August 2007, 17:59
  5. REALLY NEED HELP - ASAP
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2007, 18:25
