JMB RetrofitsVolks Autos
    Dec 2013
    North Yorkshire
    A3 2.0TDi DSG Problem
    Hi,
    I am a new poster here after lurking in the shadows for a while reading this site. So firstly I would like to thank you for all information, hints and tips I have gained from this forum.
    I now need some advice regarding a problem with my A3 DSG 54 plate. (106000 miles)
    I have read various threads and I am pretty sure I may have a goosed turbo but would like some clarification before booking it in with a garage.
    Basically, while accelerating off the drive yesterday I heard a reasonably loud 'pop' followed by sudden loss of power and plenty of dark white smoke. I quickly turned around and put the car back on the drive.
    I am aware that this could possibly mean the turbo has blown, but was looking for some basic advice on checking other possibilities myself before ringing the garage on Monday morning.
    Many thanks in advance
    Chris
    Mar 2011
    Cleveland
    979
    Dunno, maybe the hose from the turbo popped off or holed?
    Dec 2013
    North Yorkshire
    Thanks fangio.
    I have removed the cover below the engine bay and had a look at all connections and pipes heading to or from the general area of the turbo.
    They all appear to be connected with no signs of distress except one clipped connection on a large diameter pipe where there appears to be oil seeping through. There was also a large saturated area of oil on the padding attached the engine cover that corresponded with the position of the connection with the oil leak.
    Will be taking to my local garage in the morning. Would a job like this be better suited to an Audi/German specialist garage?
    Mar 2011
    Cleveland
    979
    You don't need an Audi main dealer, but if you know a garage which has a VAG-loving fitter go there; but not really a specialist job.
    I'm not very knowledgeable about turbos, but it sounds like the oil seals are cooked.
    At 106,000 it will have revolved very many millions of times at speeds of up to 150,000 rpm!
  1. Audi A3 2.0TDi DSG - problem..Mis Fire
    By sarah1989 in forum Diesel forum
    Last Post: 16th July 2009, 17:41
  2. DSG PROBLEMS ????
    By delannison in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2005, 07:35
  3. A3 Sportback 2.0TDI DSG Project
    By SimoP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2005, 06:19
  4. A3 2.0TDI DSG MPG???
    By funkycat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2005, 13:54
  5. New A3 2.0TDI DSG Sport
    By Ginge77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2003, 01:55
