Chris NottJMB Retrofits
Results 1 to 11 of 11
    Mar 2013
    158
    S3 parking control module
    Hi guys, the parking sensors stopped working on my audi s3 which has front and rear sensors
    I had the car scanned and it said it was the parking control module had a fault. I've took the parking control module out from the boot and was looking on ebay for one to replace it. Now does the number on the module have to match the replacement one?
    For example the one on mine reads 8PO 919 475 D however there is a second hand one on ebay with the number 8PO 919 475 J. If I'm correct this would be no good? I can't seem to find one on ebay with the matching part number so does this mean i need to go to audi direct and get one from them? If so how much am i looking to pay?
    Thanks in advance.
    Mar 2013
    158
    could anyone help?
    Jan 2012
    1,837
    Just do a google and see if the 8P0 919 475 J module is compatible with 8 sensors not 4.
    ie -
    The Audi TT Forum :: View topic - optical parking display on RNS-E 2010 coding
    I fitted the new PDC unit 8P0 919 475J a few days ago and had the opportunity for my local Audi service team to check the coding out, while it was in getting some other stuff done.
    Basically what they found was that this PDC unit 8P0 919 475J is actually for front and rear PDC
    Mar 2013
    158
    Just done a check on that and J seems to not work as said on the tt forum.
    Unless i can find a D second hand on ebay i may have to head to the dealers!
    Jan 2012
    1,837
    Kufatec is saying its 8 sensors
    Steuergerät PDC 8 Kanal A3 8P 5957-8P0919475J
    Feb 2011
    20
    Hi don't know if this is any use to you
    First series:
    4F0 910 283 A - 4 sensors, no graphical support
    4F0 910 283 B - ? sensors, no graphical support
    4F0 910 283 C - 8 sensors, graphical support
    4F0 910 283 D - 4 sensors, graphical support
    4F0 910 283 E - 8 sensors, graphical support, rear view camera support
    4F0 910 283 F - 4 sensors, graphical support, rear view camera support
    4F0 910 283 G - 8 sensors, graphical support, rear view camera support
    4F0 910 283 H - 8 sensors, graphical support, rear view camera support
    Second (current) series:
    8K0 919 475 AA - 8 sensors, graphical support, rear view camera support
    8K0 919 475 A - 8 sensors, graphical support
    8K0 919 475 B - 4 sensors, no graphical support
    8K0 919 475 C - 8 sensors, graphical support, rear view camera support
    8K0 919 475 D - 4 sensors, no graphical support
    8K0 919 475 E - 8 sensors, graphical support, rear view camera support
    8K0 919 475 H - 4 sensors, graphical support, rear view camera support
    8K0 919 475 R - 8 sensors, graphical support, rear view camera support
    Jan 2012
    1,837
    Those are for 4F A6's and 8K A4's ...
    Mar 2013
    158
    Thats interesting as i have 8po 919 475 d in my car now, and that list says its for 4 sensors and mine has 8!
    So if i get one of the modules from the list with 8 sensors then i should be good to go?
    Will i need to reset through vag com once the new module is fitted?
    Mar 2013
    158
    With you a6 chris, I've been told they are around £120 from the dealers.
    I may just go there and get them to sort it.
    Jan 2012
    1,837
    Quote Originally Posted by Josh williams View Post
    The modules listed above are not applicable to A3's.
    27,014
    Depending where you are, we can replace this for you & bring a module from audi over.
  1. Parking Sensor Control Module...
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th August 2013, 22:38
  2. Where is the Door Warning Lightsd Control module!?
    By GSB1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2006, 09:15
  3. Can Airbag Control Module be repaired rather than replaced?
    By Rhunster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2005, 15:29
  4. HELP! ignition control module!
    By imported_tristram in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2004, 21:55
  5. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
