Chris NottAH Fabrications
Results 1 to 7 of 7
Like Tree5Likes
  • 1 Post By Andy Crooks
  • 1 Post By s3_trev
  • 1 Post By wxc
  • 2 Post By t8ups
Thread: Non OEM LED number plate lights without error A3 2009 (59) (cheapest option)
    wxc
    Sep 2013
    71
    Sorry for starting a new thread on something that has been talked about, that is installation of LED number plate lights whether it's OEM or Non-OEM that gives bulb error on the DIS. There are currently two ways to negate this error:
    A) Using Vagcom - this simply tells the on-board computer to ignore checking the number plate lights for bulb errors, this means, as I understand, if you do have a blown LED light, it WON'T give you the bulb error message, you only find out by visual inspection. I don't have vagcom so this was not an option.
    B) adding load resistors, the best one one I found online is (someone posted this somewhere from this forum actually): Adapter plate LEDs Audi A4 B6, B7 / Audi A3 8P-39298-1 but this cost around £30.
    Or
    C) using your existing Festoon bulbs as 'load resistors', which is what I did, and as the title suggest, it really didn't cost me anything since I had all the material already.
    1) First take your festoon bulbs and 4 pieces of copper cable cut to a reasonable length. The aim is to solder the copper cables to the ends of the festoon bulbs. One tip is to first file/sand the ends of the festoon bulbs in order to roughen it for a better soldering surface. you should end up with something like below:
    2) Take the lower boot lid trim off: http://homepage.ntlworld.com/h5djr/e...lid%20trim.pdf
    Basically remove the two torx screws and pull it outwards. The photo below shows the trim removed and inside you will see four clips that hold it in place on each side. Sometimes the clips stay stuck in the boot lid itself so you'll need to use pliers to get them out (photos below).
    3) You'll need to locate the number plate socket that supplies the power.. simply pull lightly and the socket/plug should come out.
    4) Peel back the OEM black tape that surrounds the cable and you will see 4 cables in this order - Brown - Brown/Grey - Brown - Brown/Black. You'd want to tap into the Brown - Brown/Grey wires (photo attached) with your home-made festoon bulb+wires like the second photo. I used Crimp connectors to secure them together. Soldering might have been better but I couldn't do this at the time..
    2013-12-24 11.34.43.jpg2013-12-24 12.07.42.jpgAttachment 24971
    5) Then re-insert the number plate socket/plug, hope for the best, and smile when the bulb error disappears
    In summary this procedure is exactly like fitting in a proper load resister but these can get extremely hot, I suppose the festoon bulbs go quite hot as well but something tells me that they'll be fine; especially because they're not touching anything in its immediately surrounding, its located in a 'pocket' within the boot trim.
    I've had them in for a few days and so far so good. i'm sure this will work with any LED number plate lights, I went for some on ebay as they are a little bit brighter and MUCH cheaper compared to the OEM version.
    So if you have an hour or so at hand and can't stand the bulb error any longer, then feel free to give it a shot.
    Wxc
    Andy Crooks's Avatar
    Feb 2011
    Worcester
    937
    Follow Andy Crooks On Twitter Add Andy Crooks on Facebook
    t8ups has bulbs mate fairly reasonable all you would need is vagcom to clear it as thats what he did for me
    s3_trev likes this.
    S-line A3 1.2 TFSI brilliant black
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    627
    I used these exact same bulbs as you a few months ago, and I had no bulb error on the dash, but I found them much too bright. I am now using the genuine OEM LED units, and yes they are a tad expensive for all they are, but are totally worth the price IMO, rather than doing what you have done here. The main problem I see with LED number plate lights is the brightness. People / suppliers boast about how bright the lights are when in fact this isn't a good thing at all, things like 18 LEDs in a numberplate light...wise up. This is the reason why I like the OEM units, they are just bright enough but not too bright. I think having a floodlight shining down on your numberplate, illuminating a meter of road under the car looks absolutely ridiculous IMO.
    t8ups likes this.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    Mar 2010
    Somewhere
    324
    wxc
    Sep 2013
    71
    Quote Originally Posted by s3_trev View Post
    Agreed, i've seen those 18 LEDs that shine like space ship lights, complete overkill.
    I think the photo shot of my car makes it look brighter and bluer than it actually is, ideally I want one that's in between the OEM and my current ones; but you do get use to them.
    s3_trev likes this.
    Jun 2011
    Wellingborough
    1,174
    When i get members ask for number plate lights i only sell 1 type for them, they are a 2 led 3528 smd, so the really small LED's. just like it so its as bright as stock just whiter.
    Working on the 09+ lights which alot of members are waiting on as they dont have the tools etc to carry out the mod you have done.
    https://www.audi-sport.net/vb/produc...late-leds.html
    Trups
    wxc and s3_trev like this.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Feb 2011
    Worcester
    937
    Trups, you fitted mine at aitp in the summer and last night I noticed that they have a faint flicker on both left sides of the bulbs like when a bulb is about to stop working, what could be the cause?
  1. Audi OEM led number plate lights fitted with pics
    By jerseypaul in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2012, 01:13
  2. No DIS Error LED Number Plate Lights For 2010+ A3/S3's Now On Ebay UK
    By Paullie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2011, 19:44
  3. led number plate lights
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2010, 13:40
  4. LED number plate Lights....help!!!!
    By V16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2010, 21:07
  5. New Type LED Number Plate Lights
    By david_phillips95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2009, 14:26
