AH FabricationsSky Insurance
Results 1 to 9 of 9
    Nov 2013
    23
    Oil consumption on 2011 S3?
    Been doing some research as i'm knew to the audi scene and read that the 2.0 tfsi is prone to consuming oil. After reading this thought I should check mine and oil level half way between low and full. My S3 is on longlife service so had oil change a year ago so probably not too bad but my previous tuned focus RS never used any. What causes these engines to consume oil? Would an uprated PCV improve things? How much is oil for the S3 from audi?
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    750
    I think it's quite expensive from audi bud. They sell it in 1l bottles I think.
    Some buy oil from TPS etc as it's much cheaper.
    Audi A4 BE 2.0 TDI 177 Quattro
    Jun 2011
    Great Melton Norfolk
    1,356
    If you buy a drum from TPS it woks out roughly £2.30 a litre
    RPB
    Aug 2011
    Notts.
    319
    Thats not using oil if its only halfway after a year! lol. I can see why you would think it is though if your old Ford didn't use any at all.
    My 2011 S3 has used 0.4 litres in 5k miles since June when it had its last service.
    EDIT: edited to ask you, do you not check fluids and tyres every week? This is something I am very anal about. I always check fluids and tyres once per week without fail. I can't believe a lot of ppl don't even bother looking until a bloody light comes on the dash!
    2011 61 plate S3 SB BE DSG - Shark Stage 1 + DSG
    Feb 2012
    84
    but doesnt the car constantly check the oil levels itself?
    i.e. that oil service indicator. or am i getting it wrong.
    Feb 2013
    Grimsby
    1,101
    iv never checked either oil or tyres since owning the car in july :/
    Im a bad man.
    05, A3 8P 2.0TFSI Quattro
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,414
    Quote Originally Posted by Fritz-s3 View Post
    I'd avoid the long life service schedule,or at least have the oil changed maybe half way through the intervals.
    I did it once,and the stuff that comes out at the end of an interval is pretty nasty.
    One problem is that some eat oil,and others barely sip it,and you don't know until you've got one or the other,although the PCV system is another issue altogether,as it feeds oil vapour and rubbish back into the inlet,and can lead to the intake valves coking up.
    If you intend to tune it at all,it's worth getting a catch can system fitted.
    Nov 2013
    23
    Quote Originally Posted by RPB View Post
    Only owned car for about a month and the car had audi health check before i picked it up and everything was fine then. Doesn't appear to have used much but will religiously check it like yourself from now on after doing some research on oil consumption.
    Think i'll get it serviced before indicator because it's still showing another 8k miles until service which would be about a year and a half since last oil change.
    Read that the 2.0 tfsi suffers from oil consumption, is S3 engine the same or does it have different pistons etc?
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Mine gets serviced at Audi using long life oil but I get it done every 6/7k.
    I wouldn't buy a car that has been on long life services.
    Mine is on 30k now and I've never had to top up between changes.
    My MK4 Golf GTI 2.0 8v however uses around a 1l every 1000 miles lol.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
  1. A4 Cab 2.4V6 - Is my oil consumption normal?
    By imported_lewiscsfb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2005, 11:24
  2. PD130 Oil Consumption?
    By imported_Macduff in forum Diesel forum
    Last Post: 20th October 2004, 22:51
  3. Newbie... question about A3 oil consumption
    By imported_wallj in forum The Welcome Section
    Last Post: 16th July 2004, 08:23
  4. X-post for a friend: A3 Oil consumption too high
    By ImolaS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 13:13
  5. A4 TDI 130 Oil Consumption
    By neiltdi in forum Diesel forum
    Last Post: 16th December 2003, 09:25
