Results 1 to 11 of 11
    Nov 2013
    90
    Angry Help S3 (8p) fuse 5 keeps blowing,
    Hi guys not sure if this is in the right section ,but I have a problem fuse 5 in the fuse box inside drivers door area Keeps blowing straight away ( not after doing anything) a soon as I put a fuse in its gone,
    pim trying to find out what runs from it, I no the clusters do as it says that on the door, but even after removing them it still go's can anyone help or point me in the right direction. I'm thinking a trapped wire or something else faulty but just need to no if it feeds anything else, thanks
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by John ler View Post
    Hi what does the manual say fuse 5 protects as you could start by disconnecting each consumer ,I don't have my manual to hand but a stab in the dark would be a coin dropped in the lighter socket if it's protected by that fuse.
    Nov 2013
    90
    Thanks for reply, I don't have a manual , and I've disconnected the cig lighter, just need to no what's connected the fuse as it must have an earth to it somehow cheers
    I can't find anywhere on line where I can download a user manual for free, and I've only got use on an ipad as laptop packed up on me
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,091
    I have just done a quick Google search and I found one entry that says it might be linked to the AC.
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    Nov 2013
    90
    Is that the fuse 8 inside the car or under the bonnet, I've been searching for bloody hours , but found out that the S3 fuse layout is different to other models thanks
    It's a red and yellow wire that's at fault I think and it a thick wire so must carry quite some power or feed quite a lot
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,091
    I did just a quick search. I have an A3 and it's not hear. Also just read it might be part of the wiper and washer
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,091
    Have you tried to leave the fuse out and see what's not working?
    Nov 2013
    90
    Thanks I haven't checked wiper/ motor so ill discontent that tomorrow when I can get to it thanks for you help john
    Apr 2013
    Aberdeenshire
    592
    Commonly with ac it could be your compressor clutch coil or the regulating valve on the compressor or the wiring rubbed through
    If that fuse supplies the climate
    also you could do a scan with vcds and see what it says.
    Nov 2013
    90
    So if I disconnect power to the compressor should that tell me, the climate control in car works ok so that part can't be come ted to it cheers , big help this
    Nov 2013
    90
    Sorted this now, was wires in passenger side window motor had burt together, must have been an overload or something
    Thanks for your help guys
  1. PLEASE HELP. Fuel pump fuse keeps blowing! A3 1.8t 1998
    By gniknotle in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2012, 12:57
  2. F8 fuse keeps blowing 2.0TDI
    By jonnyg2k5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2009, 11:59
  3. Fuse keeps blowing
    By psychochild187 in forum Air Conditioning
    Last Post: 11th June 2009, 18:58
  4. Interior light fuse keeps blowing
    By sam4191 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2009, 11:27
  5. Horn Fuse keeps blowing
    By imported_TDi_Singh in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th April 2006, 11:16
