JMB RetrofitsVolks Autos
Results 1 to 8 of 8
Like Tree4Likes
  • 2 Post By fangio
  • 2 Post By mookster
Thread: 3.2 manual - lost all gears :(
    Dec 2012
    Hordnean, Hampshire
    157
    Just a quicky, hoping someone might know my issue...
    Got in the car this evening to nip to the shop before closing so I've food for my night shifts over Christmas. Found that I couldn't select reverse. Further checking proved I couldn't select any gear.
    Car is a 3.2 6 speed manual 54 plate. It's been perfectly fine up until now but I suspect my last journey home caused the issue. Had to wade through quite a deep puddle on the way home from work this morning, as in 6-8 inches deep for a good 60 meters or so. The car got through okay and I carried on my way. When I came to a stop later on, after a minute or two of driving and changing gear, I noticed a slight judder when pulling away, as if I'd put it in third accidentally. It was in first though and after declutching to stop the judder I was able to pull away fine and the rest of the 10 minute journey home was trouble free.
    So I'm suspecting the water has somehow caused the problem. No warning symbols are lit on the dash, car starts fine and everything else works okay. I can put the car in any gear when the engine is off but all gears are blocked with engine on. When I try to put it into gear it just hits a stop and I can feel a slight 'pull' on the engine, as if it's trying to slip into gear.
    Not content with working nights, I'm now stuck with walking to the shops and having to ride my bike to work in the rain, merry bloomin' Christmas
    Any clues?
    Feb 2009
    Aberdeen
    2,605
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Sounds like the clutch isn't happy. If you can't push the gear lever into position then that's where I'd start looking.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Apr 2013
    Aberdeenshire
    590
    Quote Originally Posted by MartayMcFly View Post
    Sounds like your slave cylinder is seized hard to say without a look
    Mar 2011
    Cleveland
    970
    Can you start it with the clutch down and in gear or does the car lurch forward?
    I've known the clutch plate to 'rust' onto the flywheel and not disengage. The above should shift it if the pedal feels normal.
    MartayMcFly and DriverN00B like this.
    Dec 2012
    Hordnean, Hampshire
    157
    Cheers chaps. Was thinking more clutch than gearbox, surprised it's gone just like that though, having been fine beforehand
    Since having the car I've always thought the clutch was a bit on/off, very little slip. Surprised me as I've had racing clutches in my old Evo and S15 that have been more forgiving. Thinking about it, over the last few weeks or so there have been one or two occasions when it didn't seem to slip into 6th quite as easily as it had previously, in hindsight I'm guessing this was the warning signs. Car's done 47k miles, so not a huge amount, but not really sure when such things might crop up on these.
    Was hoping someone might say, 'oh yeah, you just need to pull this fuse to reset it', or somesuch, but I've never been that lucky
    Dec 2012
    Hordnean, Hampshire
    157
    Fangio > Just seen your reply. Gave that a try... mate, you are my f**king hero
    That did the trick and all is good. I know brake pads often stick on after rain in that same way, so guessing a decent amount of moisture must have found its way into the flywheel/clutch area after going through the flood and did just that. It took a jolt when turning the engine over first time, usual sort of 'starting in gear' thing, but after starting it again, it went into gears just fine
    If you weren't so far away I'd buy you a beer
    Honestly, this forum
    MartayMcFly and S3_Mat like this.
    Mar 2011
    Cleveland
    970
    clutch
    Glad to help. With age comes experience!And you could always move up here...
    Mar 2011
    Cleveland
    970
    I'm having a hell of a job trying to post replies!!!!
    Just thought, I first came across your problem in 1967!!!!!!!!
  1. Lost 4th gear on 97 A4 tdi quattro
    By mtaylor55 in forum General Technical / How To
    Last Post: 3rd December 2007, 23:25
  2. Lost all engine power
    By Blunteh in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2006, 19:19
  3. Seem to have lost all my inbox and sent items?
    By cdb2 in forum Site Support & Announcements
    Last Post: 19th June 2006, 13:08
  4. DSG Lost Drive / Gear
    By MrLapou in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2005, 00:31
  5. Hello - again - lost all my posts :-(
    By Halgernon in forum The Welcome Section
    Last Post: 12th August 2005, 18:38
