Hi all. My cat is a 2.0 tdi bkd engine code 2005 model. It's done 148k and had the clutch, flywheel, slave and master cylinder replaced 47k ago.
The symptoms are sometimes lack of clutch pressure when revs are lower. Sometimes it gets stuck in 1st or reverse and the biting point can vary somewhat.
Also if I slightly rest foot on clutch pedal and put power down the pedal drops slightly. Power off the pedal rises back up slightly.
Been told it's the lay shaft bearings by a mechanic I know. I'm no mechanic but I haven't heard of bearings causing this kind of symptom. 5th gear does have a whine when bringing clutch up. I don't want to have the lay shaft bearings changed to find fault still there.
Sorry for the long thread I'm just at a loss of a definitive answer.
