AH FabricationsEM Tuning
    Nov 2013
    90
    Little help s3. 2010 8p ccm / CECM , where is it ?
    Hi guys I'm trying to find where the ccm or bcm is fitted to my s3 2010 I believe it a 8p shape, I'm having problems I have no clusters light up and no power getting to the key, and I'm thinking it could have something to do with this module, could anyone point me in the right direction and if anyone has a link to show me would be rear thanks
    Nov 2013
    90
    It's the CECM module I'm looking for guys thanks
    May 2009
    south yorkshire
    628
    in the boot ,right hand side behind panel fastens to a plastic bracket ,should have 4 plugs going into it .
    SJ
    Jan 2013
    75
    I don't own an S3 but according to elsawin it's in the same location as the A3 which is in the drivers footwell.
    You'll need to remove the plastic trim which is only held on with 3 8mm bolts, two of these are at the base and visible from floor level the third is behind the trim on the end which just pulls off (visible with the door open). The bcm is then located to the right of the steering column, surrounded with relays. It's the module with the three large 52pin connectors feeding into it.
    SJ
    Jan 2013
    75
    Images attached
  1. Aerials - A little help please!
    By S3 Wannabe in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2008, 14:06
  2. hay after a little help with my a3 1.9tdi pd atd
    By dadogfromskem in forum The Welcome Section
    Last Post: 18th March 2008, 12:25
  3. just joined and might need a little help
    By loader in forum The Welcome Section
    Last Post: 6th December 2006, 06:45
  4. Hey folks got my car rr'ed - need a little help
    By Soupie69uk in forum Tuning
    Last Post: 10th September 2005, 13:57
  5. Can any one read German? A little help may be needed.
    By Soupie69uk in forum General Chat
    Last Post: 12th August 2005, 11:11
