Chris NottJMB Retrofits
Results 1 to 10 of 10
    _Conrad_'s Avatar
    STRONIC
    Dec 2013
    Surrey
    53
    2010 s3 changing bulb colour bi xenons
    Just wondering if people have changed the bulbs to something more like 6k. Only had the car a couple weeks but bothers me that and the Fogs. Also looks like a headlight out job as well!? Any help or pictures would be much appreciated.
    Cheers Conrad
    _Conrad_'s Avatar
    STRONIC
    Dec 2013
    Surrey
    53
    Right I've found these even at the reduced price there still very expensive has anyone uses these?
    Philips Audi Blue Vision Ultra - D2S 6000k | Euro Car Parts UK’s No.1 Car Parts Retailer
    Keane's Avatar
    Jul 2013
    219
    Be interesting too know if they are much different use discount code CPLESS15 will get a little more off them.
    c_w
    1,061
    Your S3 doesn't use D2S. I think a 2009-on will be D3S. (06-08 are D1S). The HID bulb has a square ignitor box on the base.
    That's crazy money for those D2S bulbs on euro. Look on ebay, the aftermarket bulbs are fine and shouldn't cause any issues. I have some £12/pair D1S 5000k bukbs in mine atm. Or just keep your lights on at all times to try and age them they go darker :lol:
    Fitting is tight for space but it should be possible through the wheel arch. If it's just a slight colour change I honestly wouldn't not bother with the faff, a higher K rated bulb will just put out less light too.
    _Conrad_'s Avatar
    STRONIC
    Dec 2013
    Surrey
    53
    Well I'll need to check what bulbs they are doesn't say in the book as it says they need to be changed by a workshop! I'm really fussy with things like that has to be right. I've also seen these
    MTEC D2S OEM QUALITY HID XENON REPLACEMENT BULBS 6000k - HIDS DIRECT LTD Store
    obviously will need to be right fitment but a much better price and I've also had good experience with mtec bulbs. Waiting to hear from a forum member first though. Cheers for the help
    c_w
    1,061
    Still a bit dear IMO. I got genuine OSRAM D1S for £35 a pair off ebay a while ago.
    Yours is D3S
    Audi A3 Xenon Headlight OEM Bulb Ballast Problem Parts Replacement
    Some here from HIDS Direct D3S HID XENON REPLACEMENT BULBS - SUPERIOR QUALITY - | eBay
    Sep 2013
    66
    How old is your car and how many miles is on it ?
    Bulbs do get used, and it could be that yours are simply ready for a replacement. IMO the best color is the 4300-4500 kelvin. 6000 gets to blue and you loose some light with them as well
    c_w
    1,061
    But that's the opposite of what he wants, he wants bluer lights, like an aged bulb.
    _Conrad_'s Avatar
    STRONIC
    Dec 2013
    Surrey
    53
    It's a 2010. Cheers c_w i checked around the Headlights and they've got D3S bulb in you are right . I'll probably grab them and some mtec Fogs for the time being maybe put a hid kit in the Fogs later. Thanks again just waiting for trups to sort the plates bulbs now.
    Feb 2013
    Grimsby
    1,094
    Quote Originally Posted by _Conrad_ View Post
    Shift+R improves the quality of this image. Shift+A improves the quality of all images on this page..
    05, A3 8P 2.0TFSI Quattro
  1. Changing bulbs in facelift headlights fitted with xenons!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2010, 12:50
  2. Changing bulb on rear light cluster A4 Avant
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th May 2008, 22:50
  3. Changing bulbs
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2007, 20:01
  4. changing bulbs?
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 10:51
  5. How do I change bulb on A4 Avant
    By nlldavies in forum General Technical / How To
    Last Post: 11th August 2005, 18:58
