AH FabricationsVolks Autos
Results 1 to 7 of 7
    Keane's Avatar
    Jul 2013
    167
    Audi s3 rnse displaying s3 on start up?
    I've got the older model rnse and when I turn the car on it says s3 media ect ect. I'm looking too buy the later led version and replace the old one. Bit sad but will it still say s3 mmi when I turn ignition on ??
    Boon's Avatar
    Sep 2012
    South East Kent
    339
    It is coded with VCDS...
    It can simply be recoded to display a different startup screen, sorry can't remember off the top of head but about 5 or 6 different startup variations
    It could well have been out of an S3 if not original to your car or someone could have just changed it!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Keane's Avatar
    Jul 2013
    167
    Cheers pal also if anyone knows. how do I go about getting the code from the rnse that was fitted from factory in my car ?
    Boon's Avatar
    Sep 2012
    South East Kent
    339
    Just noticed it says S3 because it is in an S3 - Dur!!! Been a long day! But they can all be changed!
    You'll need the code either from the RNSE book supplied with the car/security card or from Audi & you'll need security codes for the car and all sorts to get it out of them...
    You'll only need it to sell it on, if you take it out and refit your car will remember it and won't normally ask for the code
    Keane's Avatar
    Jul 2013
    167
    Cheers I have an rsne already but just brought a newer version so will sell my older one hence the questions. Okay thanks (y) will check the manuals ect as I'm 100% sure the current rsne has been in from new, so I'm guessing will be in the folder somewhere.. On a little card ?
    Feb 2009
    Aberdeen
    2,490
    Take the car in to Audi and they can get your current unit's code. You need the chassis number and unit's serial number, but if you take the car in with the unit installed they just have to plug in their diagnostic system to get the code.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Keane's Avatar
    Jul 2013
    167
    Cheers for your help lads. Found the security card with the serial number and code so it's all good too sell if anyone's interested 👍
  1. AUDI A3 1.9 tDI not starting
    By hancliff79 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2011, 17:15
  2. My first Audi experience..... Not such a good start.
    By TheKing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2010, 18:29
  3. Audi 80e 2.0l 1993 wont start
    By bsgj1977 in forum Classic Audi Forum
    Last Post: 31st May 2007, 14:04
  4. audi coupe 2.3 e cold start problems
    By buzby3xx in forum Classic Audi Forum
    Last Post: 27th August 2006, 23:21
  5. Audi Driver Info Display
    By jonathanA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 14:43
