AH FabricationsSky Insurance
Results 1 to 8 of 8
    Nov 2013
    27
    Redline MT oil A3 Quattro
    The gear change on my recently bought A3 Quattro was superb ,couldn`t be better.However I decided to change all the fluids .I put Redline MT 90 in the gearbox (GL4) as was advised on this forum.The gearchange now is considerably worse especially from cold.No idea what oil was in the box previously.Is there any better oil than the Redline?
    Dec 2011
    Somerset
    502
    See what Opie Oils recommends.
    Cold shifts can be helped by a thinner oil like a 85 or 80
    Can a GL5 be used ? Some GL5 are too slippery and are more suited to diffs.
    Also there is a belief that GL5 can harm the brass syncro's, this is out of date as any reputable oil manufacturer won't have the additives that harm yellow metals.
    Fuchs might be worth a punt.
    Nov 2013
    27
    Redline MT 90 was what Opie Oils recommended.When I complained to them about the stiff gearchange they told me there website info was wrong and they should have sent me a straight 70.I`m sure a 70 is wrong it should be 75W90 or am I wrong?
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    Quote Originally Posted by 0120raptor View Post
    hey raptor im using the redline mt 90 GL4 myself and i have no problems if anything it made my gear changes smother , did you put the right oil int here i used just under a gallon
    c_w
    1,061
    Drain whatever you have put in, and get 3litres from a VW dealer. DON'T use anything else in this gearbox, it may cause long term damage to selector.s VW don't give the full specs for the oil on their bottles, but if you get it from there you know it's the right stuff. I would never normally advise going to a dealer for oil but in this case I do!
    The part number is G052171A2 (sold in 1ltr bottles).
    Jan 2011
    Australia
    1,316
    i think you are mistaken ive used it on my 8L s3 and now the 8P both manual, and had no issues with the oil as long as its 'GL4' / 'MT 90' then i dont see why, i even use GL5 for the rear diff and the only oil i actually buy from Audi is for the haldex
    c_w
    1,061
    I'm not mistaken in what you've used, just that to be sure of the correct oil you may as well get it from VW (who do not state the spec of the oil). The OP already stated that he has used Redline MT90 and now suffers poor gearchange, and he's not alone! All I'm recommending is going for the OEM fluid as it's designed specifically for this box, other VW manual gearboxes have different oils specified for them, so throwing in some generic GL4 / MT90 is perhaps not ideal.
    From post#22 6speed transmission fluid - Page 2 - TDIClub Forums
    OEM vs motul gear 300 tranny fluid - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    Dec 2011
    Somerset
    502
    Is Tim from Opie Oils on here as he is most car forums ?
    There is nothing he doesn't know or can't find out about.
    I've know him to recommend different transmission oils across the VAG range depending if it's a 5 speed or 6 speed.
    Wether it's has some wear or has poor cold shifts.
    Don't decide until you have heard from him, ideally by him posting on this thread to help others.
  1. Change gearbox oil a4 quattro.
    By Cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th December 2010, 22:43
  2. Redline Gear Oil
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2009, 11:07
  3. What is the best oil for a A6 2.8 quattro/98
    By imported_MADEIRA in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd March 2005, 20:50
  4. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
  5. A4 Diesel Quattro gearbox oil
    By QuattroChap in forum Diesel forum
    Last Post: 8th June 2004, 21:17
