Volks AutosAH Fabrications
Results 1 to 19 of 19
    Dec 2013
    69
    Key wont open the car but will lock it!
    I have a S3 8p 2011 sportback with 1 key - it has been alright until yesterday when I go to open the car from the key but it doesn't work! but it will lock the car and the boot button works too, do I need to sync some how?
    May 2009
    south yorkshire
    628
    dodgy button on remote ?? or are you manually opening car with the key in the lock ? broken micro switch maybe
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    sounds like you've got a faulty microswitch on your remote. Can you feel it click when you press the unlock button? new microswitches are easily soldered on to the PCB. I've done a fair few
    Please contact Admin if you wish to advertise your business/services on the forum
    Dec 2013
    69
    it clicks and sounds the same as the lock button. How much are these switches?
    I have to manually put the key in the lock to open
    Mar 2012
    356
    There's a wee light on my key that flashes when you press the button - dunno if they have that on later ones - you could see if it flashes when you press each button....
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,969
    take it apart,normally the metal contact inside is not connecting when you press the button,open it and bend the metal tabs upwards.
    Full leather/19"wheels/cruise/
    Dec 2013
    69
    The light doesn't flash when I click the open but does with the close and boot.
    I shall try opening the key If its that simple id be happy
    Dec 2013
    69
    tried to search the web is there a easy way to get in to the key?
    vw754's Avatar
    Nov 2006
    U.K
    1,969
    take battery cover off,remove tiny screws and ya there
    bit hard but they do split.[QUOTE=briniuk;2038942]tried to search the web is there a easy way to get in to
    Top Gear!
    Sep 2010
    N. Ireland
    272
    Its the battery, I had the same issue not long ago.
    Swap out the battery for a new one and you'll be fine!
    The Key splits in 2 by inserting a flat head into the slot on the back, then prise it open along the crease which should reveal the battery
    craigynett's Avatar
    Apr 2006
    300
    Quote Originally Posted by briniuk View Post
    they're usually a few quid off Ebay. You need to open the case to see which type of micro switch are mounted on the PCB. They'll either 2 or 4 solder points on each switch
    craigynett's Avatar
    Apr 2006
    300
    Quote Originally Posted by Stiggles View Post
    surely if the battery was faulty the lock & boot buttons wouldn't work. Also he's got a different style remote to you. To change the battery in the newer style all you do is pop off the rear cover
    Top Gear!
    Sep 2010
    N. Ireland
    272
    Quote Originally Posted by craigynett View Post
    I thought that myself, but I think there must be something with the wiring where it reserves enough to lock and open the boot, I had the exact issue with my key, boot opened doors locked but wouldn't open with fob
    Had to open with key in door, then if i didn't start the ignition quick enough the alarm would go off.
    It may well be something else, but might aswell try the battery as I swapped mine and its fixed it.
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    I'd start with the battery too, then move on to testing the micro switches and other possible issues (signal tests, pairing etc) if that doesn't resolve it
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Dec 2013
    69
    Ok tried the battery so that's my expertise reached, onto the next solution
    May 2012
    RETFORD, NOTTS
    1,749
    As craig said, look at micro switches. Also you'd do well to get a spare key.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    May 2009
    south yorkshire
    628
    Dec 2013
    69
    Thanks for the link - my key isn't the 1 in the pic on that eBay link its the a3/s3 key does that matter?
    How much do you guys reckon a garage would charge to repair this if I didn't want to repair myself?
    craigynett's Avatar
    Apr 2006
    300
    where are you based? if i'm out & about with work & near you at some point I could take a look at it. Most garages won't repair remotes
  1. Advanced key not in the car - will it still go?
    By BahnStormer77 in forum A6/S6/Allroad forum (C7 Chassis)
    Last Post: 17th May 2013, 21:21
  2. Lowered the car but have a problem with lights
    By Lensey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 17:16
  3. New to Audi Ownership! Want to love the car but...
    By Iceash in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2012, 22:05
  4. Lock the car with key and drivers door opens again!!
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2011, 21:55
  5. New Audi A6 owner..love the car...but.....
    By tristancarroll in forum The Welcome Section
    Last Post: 2nd October 2003, 11:45
