Connorb5anda
Hi all,
Ive recently purchased an S3 pre facelift and its great fun however there are a couple of minor teething problems I would like to sort out and was hoping for some help....
Firstly the heated rear windscreen doesn't work - Ive checked the fuses ( and the forums ) and have had no luck. So i put a circuit tester on the two soldering tabs here:
Which made a circuit!
I then noticed this on the other side which was a little more concerning.... not too sure why anyone would need to solder here....
Then I realised that just because I am getting a circuit at the two soldering point doesn't mean that the windscreen heating element is not broken as it could be making a circuit back into the car.
Is the next best thing to take the wires out of the module pictured above and test the wiring going through the car and forward?
also the rear heated button led stays lit only when engine is running - when just the ignitions on it goes off after a couple of seconds
The other problem is, and could be me being a numpty... the coming home lights do not work - no Led lighting ever no matter if I hold it tap it anything. Ignition on / off - light /dark it doesn't matter its dead. Anyway of testing this with VCDS?
My first suspicion is the clifford alarm that is installed - after about 30 seconds the immobiliser kicks in and seems to cut some power to the car. I have a booking in with some guys in Guildford to remove it as its a bit overkill where I live so I guess reviewing this once removed might make sure there is nothing complicating the issue....
Any help would be great - and very appreciated...
Connor
Connor
