Badger5Sky Insurance
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By RobbieWebs
  • 1 Post By OCD-A3
Thread: water meth
    Sep 2012
    85
    water meth
    Hi guys im currently looking into running water meth at the moment on the s3, im running apr stage2+ i know it wont make much difference unless its mapped in but this also has its problems etc, apr do a 104octane map would this be better when running water meth? iv been reading about people saying water meth damages the throttle body? can anyone confirm this
    thanks in advance adam
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    903
    Yes seen in damaged a TB before.Should be ok if it is injected after the TB.
    Yes needs mapping in for the best effect.
    Growing old is mandatory, growing up is optional
    Sep 2013
    66
    I had a customer here in Denmark with a Seat Leon Cupra with APR 2+ that used water meth and ran the 104 octane map.
    Just make sure you do a little work with vcds when you install it and get the correct size nozzle. It should not pull a lot of timing running the 104 map with water meth but the trick is to find the correct size nozzle. Not to big and not to small
    From what I remember he gained 30 HP from the 98 map
    Sep 2012
    85
    how was he injecting the mixture? through a spacer or in the up pipe?
    Sep 2013
    66
    Quote Originally Posted by Adamj View Post
    BSH throttle body pipe
    Sep 2012
    85
    what mixture was he running? as it can damage the throttle body? i wonder if anyone has designed a metal one for the 2.0tfsi yet
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    735
    Speak to S3Alex. I'm sure he can advise u what would be best, just look at his thread
    S3Alex likes this.
    Audi A4 BE 2.0 TDI 177 Quattro
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Hi Adam,
    On a stock turbo,you will get a bit more power,but only if you specifically map for it,and you then need to ensure you don't run out of water/meth,as to take advantage of it,the timing will be significantly advanced.
    There is a potential risk of methanol attacking the throttle butterfly,and causing failure,as it's made of ABS,and USRT in the States can sell a spacer to allow injection above the throttle body.
    You would need a 1 bar check valve in the system to ensure that water/meth isn't pulled into the manifold under vacuum,during throttle closure.
    Having said that,mine had it's throttle body replaced recently for an unrelated problem,and after 30 000 miles using an AEM system,there were no problems.
    So in short,yes,you will see some benefits,but only if you map for it,and in any case,the poor old K04 is pretty much done by 380bhp on the airflow front.
    You get much bigger gains from WMI on a big turbo system.
    Jul 2011
    106
    INA Engineering also makes a throttle body spacer so you can inject post-TB. It is slightly improved over the USRT spacer in that the nozzle placement is offset such that it doesn't interfere with any factory installed bits in the area (if I remember correctly, it was the dipstick that was in the way with the USRT spacer.)
    As S3alex mentioned, you will need a check valve when the nozzle is placed post-TB to prevent siphoning. A few companies offer nozzles with integrated check valves, Aquamist is one.
    With APR's tune, you can run the 104 octane map as is with water meth injection. Their rep has commented on one of the US forums that they don't offer a W/M specific map because it would be virtually identical to the current 104 map. Sure, you may ring a few more HP out of it with a custom tune, but it won't hurt to run the off the shelf map. Just don't run out of juice while you're on that map! Aquamist offers a failsafe that opens the wastegate if you run out, not sure if any other brands have a similar feature.
    S3Alex likes this.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    That's a lot of good points and advice.
    I know Aquamist do both include and also sell check valves and AEM also include check valves now.
    Of the two systems,the AEM is easier to setup and use and the Aquamist does require more engine sensor feeds to work.
    Like we've both said,the issue with mapping specifically or using a 104RON map is that you must ensure the system is working.
    Also the gains on a stock turbo aren't going to be huge.
    Sep 2012
    85
    Thanks for the reply Alex, I was looking in the golf fourm about meth fitted and some pole were getting 50bhp more in the midrange, and more torque as well, hardly anything top end. Also it would be good I clean my valves etc as iv just hit 50k..
    I have been looking at either the gt30 or to send mine off for a hybrid, I haven't made my mind up yet
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    I think it would be very optimistic to think that you'd get 50bhp from a K04 already run pretty close to,or at it's limits.
    As you already have an APR map on your car,I would say your best bet is the APR Stg3 kit,which uses a GTX2867 turbo,and Decked-S3 has one of these on his car,and is very happy with it.
    It's not a cheap option,but does include everything you need,whereas kits like mine(ATP) do often require more work,although the potential of greater power etc is there.
    I honestly wouldn't bother with a hybrid,unless it's something from Loba,such as the LO4xx,which will also get you well into the 400's.
    Sep 2012
    85
    Good point what power are the rods and pistons good for? Iv been told I can just change the rods as the pistons are good for 500-600 just not the rods,
    Il try and get the link later to see what you think about the golf thread,
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    I think that most us accept that the realistic reliable(i.e. everyday) limits for the S3 internals are around 440-480bhp,and around 460lbs torque.
    It's torque that kills rods or gearboxes,and that's what you need to keep a watch on.
    To be honest,if I had the engine in bits to swap out the rods,I would also do the pistons and big end bearings as well,and that's exactly what we did with mine.
    PEC rods,Wossner pistons and race-spec bearings.
    I certainly would not try to get 600bhp from an engine on stock pistons.....mine runs a lower CR thanks to the Wossner pistons( 8.5:1 as opposed to the stock CR of 9.5:1),and whilst that isn't strictly neccessary,it will certainly be useful if you intend to run a lot of boost,but it will knock a bit off immediate throttle response.
    I'm sure you'll find people saying they've had xxx horsepower and huge torque levels from a stock engine,but what I wanted was something tough and reliable,and I think running an engine close to it's limits will end in tears.
    I have a friend who's getting over 600bhp on pump fuel from his Golf R,but the engine is a work of art,with no expense spared.
  1. Replies: 28
    Last Post: 27th January 2013, 13:28
  2. Water Meth Injection
    By D2NY G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th August 2012, 09:19
  3. water meth
    By flying oyster in forum Diesel forum
    Last Post: 8th March 2012, 19:07
  4. Water/Meth Injection
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2011, 15:43
  5. Water Meth injection
    By S3 Big Andy in forum Tuning
    Last Post: 22nd May 2009, 09:38
