Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Dec 2013
    69
    S3 sportback 2011 8P Upgrades list?
    Does anyone have the link to a PDF or know the parts list for the Audi S3 8P IE Bose system, RNS-E DVD nav system etc?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Bose - don't bother, not worth it. Better putting your money into an aftermarket system.
    RNS-E - easy retrofit, just buy the unit, remove old unit, install new unit and enjoy. Just a plug and play item.
    Muzza80's Avatar
    Oct 2013
    Glasgow
    554
    Quote Originally Posted by Boydie View Post
    RNSE is not really a plug and play item on a newer car...
    You need to ensure the new one is coded in properly with VCDS and unless you want to put up with **** radio reception and error codes stored on your head unit you need to make up a custom loom and change the large and small antenna amplifiers in the tailgate for the diversity setup that a factory fitted car came with.
    You also need to re-arrange some wiring and buy a new plug from Audi if you want to retain the factory fitted AUX port by the handbrake.
    That said, it's a very worthwhile mod, I've been very impressed with the 2011 RNSE unit I bought.
    2010 Audi S3 Sportback Black Edition TFSI Quattro
    Dec 2013
    69
    Muzza what is the part number for the DVD ? can you also get the nav on SD card?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Didn't know that about the facelift but in the pre facelift you can just slot it in and works a treat
    Nav is read from CD only
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by briniuk View Post
    The 2014 DVD part number is 8P0 919 884 BQ
    And no you can't put the contents of the DVD on to an SD card an run it.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Dec 2013
    69
    Looking on ebay this could be expensive for a 2014 version is there much difference really from me buying a cheaper 2011 version? Does anyone know the code for the 2011 nav cd
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    728
    Speak to NHN, he can supply u with an RNSE and map disc
    I got RNSE retrofitted and I didn't upgrade the antenna etc and my radio is great
    Agree with above Bose is good when u get it for nothing when u get the car, don't think if retrofit it tho for the price.
    Plus Bose and RNSE "can" be prone to volume issues mainly audio pilot mic.
    Better/ cheaper upgrading the speakers in the car for a noticeable difference
    Audi A4 BE 2.0 TDI 177 Quattro
  1. Sportback interior lights upgrade
    By S3 Dave in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th May 2011, 07:22
  2. Upgrade list for bigger front brakes
    By H2o-uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2009, 16:53
  3. A3 sportback S-line upgrades...
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2007, 12:45
  4. A3 Sportback Price and Spec Lists
    By scoTTy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2004, 17:41
