Sky InsuranceAH Fabrications
    Feb 2012
    Blackburn/Reading
    44
    Starting problem a3 2.0 tdi and DSG box
    Had my car a few months now and whenever the car is cold it turns over for quiet a while then it starts. Once it starts it's fine then once warm it starts first time. It's never not started but it's starting to annoy me now. Also with my DSG box when I put it in reverse and put the throttle on straight away there's nothing there then after a second or two it like bangs into gear so was wondering if anyone has experienced either.
    Sportback owner
    Apr 2007
    France
    492
    Cammy, first of all I would have your battery load-tested. Any decent garage or battery shop will do this for you. Better get this sorted before the really cold weather kicks in. There is a possibility that you will need a new starter if the battery checks out OK. There are many threads on this, so just make a search. The starter motor failing to give a good start is a well known problem on the A3. On the DSG box, when selecting reverse, there is indeed a delay before the clutch engages. Not quite sure why they did this, but it is there. If you have reverse-assist, then do what I do and don't give it any throttle until after you hear the beep. If no reverse assist, then just be patient and give it a few seconds for the clutch to engage. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
  1. Cold start problem - A3 2.0 TDi 170
    By matt_t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2014, 00:12
  2. Audi a4 2.0 tdi VERY poor fuel economy and engine starting problems.
    By audi 88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th July 2011, 10:54
  3. First Audi, 2.0 TDI Sport Dsg, and pos gearbox problem
    By jin2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2010, 18:53
  4. 3.2 v6 engine and dsg box for sale
    By mark a4 tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2009, 23:14
  5. 3.2 v6 engine and dsg box for sale
    By mark a4 tdi in forum A3/S3 Forum (8L Chassis)
