EM TuningVolks Autos
Like Tree1Likes
  • 1 Post By Paullie
Thread: SRI rest
    ilim's Avatar
    Nov 2011
    631
    Exclamation SRI rest
    I have been trying to do a Sri Rest with VCDS but it does not turn the reminder off. I have tried the SRI button, no luck and then Instruments, adaptations, Ch 02- new Value 0 and still no hope. Is there something I'm doing wrong?Thanks folks
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,083
    Hiya Ilim! Here is the exact VCDS procedure for resetting the service light on MY10 onwards 8P3's. I gave the same instructions to Mark the other day and it worked for his S3. Paula xx. 1) Open VCDS application and connect to vehicle 2) Switch ignition on 3) Click Address 17 INSTRUMENTS and select ADAPTATION 4) Go to CHANNEL box - change number in box to 40 5) Click on READ 6) Go to VALUES box and change value to '0' 7) Click TEST and SAVE 8) Click on YES, confirming you are sure to save changes 9) Carry out identical procedure for channels 40, 41, 53, 55, 02 (in this order) 10) Exit VCDS by clicking DONE, GO BACK and close VCDS 11) Cycle ignition to confirm service reset has been successful.
    ilim likes this.
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    564
    I had this problem last time I serviced my car, I found resetting it using the Canadian setting SRI reset option removed it for me.
  1. S3 Centre Arm Rest
    By chrsbkr5 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2007, 19:57
  2. arm rest
    By 17AUG2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2005, 22:18
  3. Arm rest?
    By Pontio in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2005, 09:38
  4. Light inside arm rest - Anyone installed?
    By lwen in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 19:42
  5. 12V supply into arm rest
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 12:30
