EM TuningJMB Retrofits
Results 1 to 19 of 19
    Jul 2009
    42
    Electrical fault! Multiple issues with my sportback...help
    Hey all,My 2005 sport back 1.9 TDI is acting weird! I've had a scan for similar problems but no one seem to have my exact symptoms. - driver side door fails to lock/unlock via key fob but locks fine with key. All other doors lock fine with key fob. When lock with key and use fob hazards work but if I don't lock drivers door manually no lights flash.- driver side wing mirror doesn't work at all but passenger side works fine.- driver window does go up and down but a bit juddery not like passenger window which again works fine (driver window goes down by itself if held but doesn't go up).Any ideas guys? I want to replace the loom from pillar to door but if it was that, everything would be dead? Any help would be really appreciated as its been ongoing for a while now.Cheers Gussy
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    903
    Could be an intermittent connection though in the rubber boot.
    Growing old is mandatory, growing up is optional
    Jul 2009
    42
    Symptoms are constant not intermittent though? Do you mean the rubber boot between door and pillar?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    903
    Ahh right yeah but seeing as it's only the one door being effected i'd try a circuit test from both sides and move the door to as it may/may not connect on door movement.
    Jul 2009
    42
    Yeah I may try some fault finding with door open and closed. Will post what I find on here later. Cheers for reply mate.You think a con check between left and right boot connection will work?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    903
    it will rule out a broken wire for sure.To get to the core of a wire use a pin to pierce the covering then put the tester on that.
    Jul 2009
    42
    Got this on vagcomAddress 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 E Component: Tuersteuerger. H10 0040 Coding: 0000048 Shop #: WSC 06314 000 00000 VCID: 3D753DC71DE12 Faults Found:00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent00928 - Locking Module for Central Locking; Front Driver Side (F220) 008 - Implausible Signal
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    903
    If the door locks are made of cheese like the range before them (ie golfs/leons) could well be the door lock module.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I had that fault last weekend. it was an earth. Had it on both doors though so may not be the same issue.
    Jul 2009
    42
    Yeah autolatry that's what's so weird. I expected the faults to be apparent on both side as I presumed they are on the same circuit?
    Jul 2009
    42
    Just a quick update. I took apart the loom to find wires twisted and snapped!!! Have no idea how it happened but I'm going to be taking it out and inline splicing 2 of them. Hoping that sorts the issues! See pic
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Wtf. Quality Audi install there then. Glad you found the problem.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    903
    Nice one for finding them
    c_w
    1,061
    Missed your post, and was about to say it's definitely the wires broken in the door loom! (you might find an old post of mine a few months ago with the same problem). Mine was exactly the same, door lock and mirror not working. And they had broken in the same way, they look almost as if they have been cut!
    There is too much wire length between the door and the body so it obviously gets trapped and bent too much when it's closed and they break. I just soldered them back together and everythings back working ok now.
    Jul 2009
    42
    Yeah gunna do it on Friday. I'm going to order some wire just in case there's not enough to splice. What gauge wire do you think?
    Jul 2009
    42
    Also, has any one got a top tip to get that connector off?
    c_w
    1,061
    The clip for the connector on the body is on the "back", just reach round with a finger and it's in the middle, press it in and waggle the connector out. Ignore the purple bit, it's nothing to do with the clip.
    On my car I removed the boot completely so I could solder the wires back together. Now one issues with this is the boot on the door appears to clip round a loose piece of plastic inside the door itself so looks like it needs the door trim removing to put it back on properly (not got round to doing this yet!). To remove the boot completely I slid it over the connector once it's disconnected, it can be done when warming it up and using washing liquid on the connector so it slides through.
    Jul 2009
    42
    Update.
    I took boot away from pillar and door and spliced an 18awg bit of wire in. Wrapped it up and fitted boot back together. All is well now!
    Tips for anyone in future...if you take the boot away from the door the best thing to do in order to get it back on properly (avoiding water ingress) is to take door card off and remove speaker to get behind the plastic clip. Push it out from inside, fit boot over said plastic clip and push it back in.
    Cheers for help guys
    c_w
    1,061
    Still need to put the boot back on the door on mine!
  1. Serious braking issue with my car! HELP!
    By pandoo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2012, 14:50
  2. So many issues with car!!!!!!! Anyone help.
    By s33nyboy12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2012, 20:32
  3. Big issue with S4 B5, Help please
    By JasonK in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2012, 09:00
  4. electrical fault audi A3 (2000 reg) Please help
    By stigger in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2008, 09:52
  5. multiple issues with A3 1.8T (Not S3)
    By Scrappy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2007, 15:01
