Volks AutosMonster Motorsport
Results 1 to 8 of 8
    Harveysmith's Avatar
    Oct 2013
    86
    A3 2.0 TDI S Line common faults
    Hi Guys
    my brother is going to look and hopefully buy a 2007 A3 8p 2.0 lt TDI 170 on the weekend. Got all the service history, can just been done. Is there anything he should be looking looking for or any common faults to watch out for?
    thanks
    c_w
    1,061
    Test the clutch; drive in 4th 5th or 6th and accelerate from 1800rpm to see if it slips.
    Ask if it's had the injectors done on the (free) dealer recall. They replace all 4 and the loom if not already, so it's not a major issue if it hasn't been done yet (might be worth a call to AUDI to enquire it will still be done FOC).
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    How many miles has it done? I think it will have a DPF but someone else will need to confirm this???
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Oct 2013
    86
    90k I think
    Suckin' Diesel
    Dec 2013
    Scottish Borders
    14
    I have the Special Edition which I'm fairly sure is the same 2.0 170 engine but with different interior/exterior spec and it has a DPF, the only thing to be sure of is running the engine up to temperature (10min drive) to ensure the DPF has time to burn off the particle thingys otherwise it will block up. Removing the DPF used to be an option to prevent this happening but new MOT laws state that if fitted then a DPF must be present.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    When was the cambelt changed last? Should be done every 75K or every 5 years.You might want to check the DPF with that mileage, assuming that it has one. Audi recommend changing the DPF at that kind of mileage and it will cost close to the grand mark.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,207
    manual or auto? If auto make sure the dsg oil changes are done at the correct intervals, 38kish. DPF problems do occur, but worst case scenario you could get it gutted. Also make sure waterpump was changed with the cambelt.
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Oct 2012
    Warrington, North West
    986
    170s have DPF yeah. From my experience engine mounts are common fault with the 2.0tfsi using same mounts (please correct if I'm wrong)
    Abs pump seems fairly common
  1. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th August 2012, 23:31
  2. Some faults on my A3 2.0 TDI S line DSG, please help?
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2011, 15:24
  3. Buying a A3 TDI 2.0 - Common Faults?
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2009, 12:15
  4. 2005 2.0 TDi S-line Faults
    By razputin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2008, 20:41
  5. A4 2.0T FSI Quattro S-line common fault?
    By tmitch45 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th August 2007, 12:07
