JMB RetrofitsSky Insurance
Results 1 to 9 of 9
Thread: Simple question
    Jun 2013
    Bridlington
    144
    Simple question
    Well simple question i hope, basically bought some new wipers as my wipers didn't seem to clean my windscreen well but since i put new ones on i have the same problem. It misses an area when it goes across it doesn't touch it so it's leaving a big gap that isn't getting wiped and it's fairly dangerous as it's directly in front of me, can't understand why it's missing, any ideas?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    906
    Weak arms or dodgy windscreen?
    Growing old is mandatory, growing up is optional
    27,121
    Just bend the arms to add more pressure & wipe fully.
    Jun 2013
    Bridlington
    144
    Thanks guys will try bend the arms a tad to make more contact with the windscreen, will let you know the outcome!
    Jun 2013
    Bridlington
    144
    Bending the arm doesn't seem to work, or i might not be doing it enough. However i know I've bent it a bit and it's still not contacting the windscreen in the middle of the wiper, i'm thinking it could be the spring/arm related? any other ideas to fix this or should i stop being a wuss and bend it more?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    906
    The spring goes weak, i tried the bending before and made it worse like you have found.
    Jun 2013
    Bridlington
    144
    Quote Originally Posted by LEE69 View Post
    Is it possible to fix or should i get a new wiper arm?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    906
    A new wiper arm i had to get, well 2nd hand.
    Jun 2013
    Bridlington
    144
    Bought a new wiper arm, this has to solve the problem just hope the one i have bought is good condition...
  1. Simple question - Servicing - what do they check?
    By murkins in forum Diesel forum
    Last Post: 11th February 2011, 16:48
  2. simple question regarding vag-com
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd November 2007, 16:19
  3. Simple question Tyre change
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2007, 15:43
  4. A couple of simple questions ...
    By wigginer in forum General Technical / How To
    Last Post: 3rd August 2004, 21:03
  5. simple question about my 1.8t
    By sport99quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2003, 22:31
