Volks AutosAH Fabrications
    Jul 2013
    11
    Emissions Light on. Exhaust temp sensor fault?? Help Needed VCDS results Attached.
    Hi AllSome help needed please.56plate 2.0TDI 170 SlineYesterday I have had the emissions light come on my dashboard.I have given it a good hour and half motorway run today hoping it might be a DPF issue and it would clear. The error hasn't cleared, so I borrowed a friends VCDS and ran a scan today.The results are below. It shows two issues, I was just wondering if one of them could be causing the emissions light (pretty sure its the exhaust sensor). Does anyone know what sort of cost its going to be to fix these faults or is their something else amiss? I cleared the faults but the emissions light stays on and shows the exhaust sensor fault again when scanned.Thanks in advance for your help
    27,007
    Your friends using a fake illegal cable.
    Jul 2013
    11
    00-Steering Angle Sensor -- Status: OK 000001-Engine -- Status: Malfunction 001002-Auto Trans -- Status: OK 000003-ABS Brakes -- Status: OK 000008-Auto HVAC -- Status: Malfunction 001009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: OK 000025-Immobilizer -- Status: OK 000033-Flux Capacitor -- Status: Malfunction 001037-Navigation -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: OK 000046-Central Conv. -- Status: OK 000052-Door Elect, Pass. -- Status: OK 000055-Xenon Range -- Status: OK 000056-Radio -- Status: OK 000062-Door, Rear Left -- Status: OK 000072-Door, Rear Right -- Status: OK 000076-Park Assist -- Status: OK 000077-Telephone -- Status: OK 00007D-Aux. Heat -- Status: Malfunction 0010 -------------------------------------------------------------------------------Address 01: Engine Labels: 03G-906-018-BMN.clb Part No SW: 03G 906 018 DN HW: 03G 906 018 DN Component: R4 2.0l PPD1.2 G 4350 Revision: --H32--- Serial number: AUX7Z0F8FNM0IA Coding: 0000078 Shop #: WSC 01089 210 97503 VCID: 74E71A2D175C86CC4D9DE02 Faults Found:000801 - Engine Speed Sensor (G28) P0321 -- 006 -- Implausible Signal - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 12 Mileage: 113328 km Time Indication: 0 Date: 2013.12.04 Time: 09:21:18 Freeze Frame: RPM: 192 /min Torque: 0.0 Nm Speed: 0.0 km/h Time: 0.01 s Angle: 0.0 ° Bin. Bits: 00000000 Bin. Bits: 00000001001140 - Exhaust Pressure Sensor 1 (G450) P0474 -- 006 -- Intermittent - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 157 Reset counter: 40 Mileage: 114330 km Time Indication: 0 Date: 2013.12.11 Time: 13:46:40 Freeze Frame: RPM: 1888 /min Torque: 184.0 Nm Speed: 0.0 km/h Voltage: 12.09 V Mileage: 300 km Text: 104 C Pressure: 1022.4 mbarReadiness: N/A
    Jul 2013
    11
    ok, thank you, I didn't know that. Could these readings then be wrong?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Your flux capacitor is malfunctioning!!
    I wouldn't plug dodgy cables into your car if I were you.
  1. Error 001137 Exhaust Pressure sensor Fault. Advice
    By a3mad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2013, 12:33
  2. Emissions Light and Exhaust Gas
    By aadams1x in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2010, 22:04
  3. 2.0 TDI Temp sensor change, help needed please
    By tommy18 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2010, 17:21
  4. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
  5. Exhaust temp sensor confusion
    By Tuffty in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2009, 22:03
