Sky InsuranceEM Tuning
    _Zerocool_'s Avatar
    Jan 2013
    217
    Electric window problem.
    Last night I tried to put the drivers window down on my car (2010 S3) and it went down about half way and stopped.
    I tried pushing the button again and nothing happened. Tried to put it up. nothing. Tried again then it worked, then it didn't then it did etc... This was the case with all the windows. Weird.
    Tried them today and they work fine
    I've had a problem with them before where pushing the button all the way down (so that the windows go all the way down) didn't work but pushing it half way did.
    Anyone else had this problem? Fixes?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,856
    Had a similar issue with the O\H's Polo, it turned out the contact pins in the drivers door switch were loose & intermittent - a few twists of the switch tightened them up & all is still well with the world.
    2009 A3 SB 2.0T DSG S line
    _Zerocool_'s Avatar
    Jan 2013
    217
    Yeah thought it may be a loose connection of some sort. Cheers Artimus
  1. Electric Window Problem
    By madmonzsta in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2007, 18:39
  2. electric window problem :(
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2006, 09:51
  3. S3 Electric Window Problem :(
    By jonS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2006, 22:51
  4. central locking and electric window problem
    By cliffyeee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th August 2006, 10:06
  5. A4 1.9 TDi B6 - Electric Window problem
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2006, 22:46
