AH FabricationsEM Tuning
Results 1 to 9 of 9
Thread: Any ideas?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Any ideas?
    Think I have plugged few things in the wrong place...
    Sunday,08,December,2013,14:35:06:44556
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: License Plate: SCAN 3
    Mileage: 163980km-101892mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56
    VIN: WAUZZZ8P54A074594 Mileage: 163980km/101892miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 CA HW: Bas isX 3
    Component: MOTRONIC ME7.1.1 0005
    Revision: 00000000 Serial number: AUX7Z0C7FNJ010
    Coding: 0000172
    Shop #: WSC 06435 000 00000
    VCID: 4C912B162F651B7E38B-8019
    12 Faults Found:
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 002 - Signal too Low - Intermittent
    17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
    P1165 - 002 - System too Rich - Intermittent
    17499 - Mixture Regulation; Bank 2; Range 1
    P1091 - 002 - Rich Limit Exceeded - Intermittent
    17599 - Linear O2 Sensors: Before CAT
    P1191 - 008 - Reversed - Intermittent
    16395 - Bank 1: Camshaft A (Intake)
    P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 002 - Signal too High - Intermittent
    17951 - Angle Sensor 1 for Throttle Actuator (G187)
    P1543 - 002 - Signal too Small - Intermittent
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
    P1172 - 002 - - Intermittent
    17763 - Cylinder 1 Ignition Circuit
    P1355 - 004 - Open Circuit - Intermittent
    17775 - Cylinder 5 Ignition Circuit
    P1367 - 004 - Open Circuit - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 002 - Signal too High
    16455 - Sensor for Ambient Air Temperature (G17)
    P0071 - 004 - Implausible Signal
    Readiness: 0010 1001
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No: 1K0 907 379 E
    Component: ESP ALLRAD MK60 0103
    Coding: 0021128
    VCID: 346153F6579563BE40B-8061
    2 Faults Found:
    00003 - Control Module
    014 - Defective - Intermittent
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 C HW: 8P0 820 043 C
    Component: KlimavollautomatH11 0130
    VCID: 2C514B968FA53B7E18B-8079
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 163981 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 18:20:28
    Freeze Frame:
    ON
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 163982 km
    Time Indication: 0
    Date: 2013.04.14
    Time: 00:06:53
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H29 0501
    Revision: 00029000 Serial number: 00000000173886
    Coding: 018CCF01A0141000000000000000000000
    Shop #: WSC 00000 000 00000
    VCID: 3B7378CA7ACBACC6811-806E
    Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
    Component: Wischer WWS Audi350 0180
    Coding: 16711696
    Shop #: WSC 00000
    No fault code found.
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0411602
    VCID: 45871E320C0FEA36E75-8010
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 009 0030
    Coding: 0000012
    VCID: 30695FE6A38D5F9E243-8065
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 J HW: 8P0 920 980 J
    Component: KOMBIINSTR. VDO H25 0110
    Revision: D06 Serial number: 2247CD06001010
    Coding: 0005403
    Shop #: WSC 00581 210 64475
    VCID: 3E7571DE69D9B9EEA6F-806B
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 7
    Fault Frequency: 17
    Reset counter: 148
    Mileage: 163981 km
    Time Indication: 0
    Date: 2013.04.02
    Time: 16:58:46
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 2400103805E43F
    Coding: BD0F0340070101
    VCID: 2645B9BE9149012ECEF-8073
    Address 22: AWD Labels: None
    VCID: 55A7CE72BCAF5AB6975-8000
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0C7FNJ010
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000048
    VCID: 397F62C270F79ED693D-806C
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 D
    Component: EPS_ZFLS Kl.10 1201
    VCID: 2D574692B4BF32760F5-8078
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - - - MIL ON
    Freeze Frame:
    Mileage: 3960 km
    Count: 1
    Steering Angle: 0.00°
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 198800186D288505485AC63000
    VCID: F9FF22C2B077DED653D-80AC
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    1 Fault Found:
    01134 - Alarm Horn (H12)
    000 - -
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Coding: 0000048
    VCID: 3A7D7DCE75F195CE9A7-806F
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 195 HW: 8P0 035 195
    Component: symphony II EU H54 0400
    Revision: 18S Serial number: AUZ5Z4C5310279
    Coding: 0000201
    VCID: EFEB1C9AFE338066FD9-80BA
    Jan 2012
    1,837
    Did you clear and rescan?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I did yeah. I did find an earth that wasn't earthed which got rid of a few codes. Then I scanned it again and thats what is above.
    Ive dropped a bollock somewhere, I have two plugs with nowhere to go and I'm not confident a lot of the others are in the correct place. Ffs.
    The camshaft one really concerns me seeing as the engine just been rebuilt... I've not started it yet, I wanted to clear all codes before i try.
    Oh also, the large fan is constantly on when I turn the ignition on.
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by autolatry View Post
    what at is the most upto date scan your fan running could be due to your cts not being connected ?
    are you sure you have secured every earth
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I've got plugs in the thermostat and radiator temp sensors and I was reasonably confident they were correct. If the wrong plug is plugged in could it be constantly sending current to it?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Or sending the wrong signal to the ecu should I say
    Apr 2013
    Aberdeenshire
    595
    Most plugs are different sizes or slightly differently shaped to avoid mix up's however if it is possible it would baffle the ECU is the earth above the vvt solenoids ok
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    getting there. does anyone know where the sensor G17 is on the car? cant seem to see it around front of the car.
    Friday,13,December,2013,19:05:37:44556
    VIN: License Plate: LATEST
    03-ABS Brakes -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    Coding: 0000172
    1 Fault Found:
    Readiness: 0110 1101
    Coding: 0021128
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 163981 km
    Time Indication: 0
    Date: 2013.04.06
    Time: 18:20:28
    Freeze Frame:
    ON
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 163982 km
    Time Indication: 0
    Date: 2013.04.14
    Time: 00:30:50
    Freeze Frame:
    Coding: 16711696
    Shop #: WSC 00000
    Coding: 0411602
    Coding: 0000012
    Coding: 0005403
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 18
    Reset counter: 148
    Mileage: 163981 km
    Time Indication: 0
    Date: 2013.04.02
    Time: 16:58:46
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554
    Component: HALDEX 4Motion 0101
    Coding: 0000001
    VCID: EADD0D8EC5D1654EAA7-80BF
    Coding: 0000048
    1 Fault Found:
    000 - - - MIL ON
    Freeze Frame:
    Mileage: 3960 km
    Count: 1
    Subsystem 1 - Component: Sounder No Answer
    1 Fault Found:
    004 - No Signal/Communication
    Coding: 0000048
    Coding: 0000201
    Apr 2013
    Aberdeenshire
    595
    getting there. does anyone know where the sensor G17 is on the car? cant seem to see it around front of the car.Friday,13,December,2013,19:05:37:44556VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: License Plate: LATESTMileage: 163980km-101892mi Repair Order: Chassis Type: 8P (1K0)Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56VIN: WAUZZZ8P54A074594 Mileage: 163980km/101892miles00-Steering Angle Sensor -- Status: OK 000001-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: OK 000008-Auto HVAC -- Status: Malfunction 001009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: Malfunction 001019-CAN Gateway -- Status: OK 000022-AWD -- Status: OK 000025-Immobilizer -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: Malfunction 001046-Central Conv. -- Status: Malfunction 001052-Door Elect, Pass. -- Status: OK 000056-Radio -- Status: OK 0000 -------------------------------------------------------------------------------Address 01: Engine Labels: 022-906-032-BDB.lbl Part No SW: 022 906 032 CA HW: Bas isX 3 Component: MOTRONIC ME7.1.1 0005 Revision: 00000000 Serial number: AUX7Z0C7FNJ010 Coding: 0000172 Shop #: WSC 06435 000 00000 VCID: 4C912B162F651B7E38B-80191 Fault Found:16455 - Sensor for Ambient Air Temperature (G17) P0071 - 004 - Implausible SignalReadiness: 0110 1101-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl Part No: 1K0 907 379 E Component: ESP ALLRAD MK60 0103 Coding: 0021128 Shop #: WSC 06435 000 00000 VCID: 346153F6579563BE40B-8061No fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 C HW: 8P0 820 043 C Component: KlimavollautomatH11 0130 Shop #: WSC 06435 000 00000 VCID: 2C514B968FA53B7E18B-80792 Faults Found:01317 - Control Module in Instrument Cluster (J285) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 148 Mileage: 163981 km Time Indication: 0 Date: 2013.04.06 Time: 18:20:28 Freeze Frame: ON01206 - Signal for Duration of Ignition Off Time 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 148 Mileage: 163982 km Time Indication: 0 Date: 2013.04.14 Time: 00:30:50 Freeze Frame:-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H29 0501 Revision: 00029000 Serial number: 00000000173886 Coding: 018CCF01A0141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: 3B7378CA7ACBACC6811-806E Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0180 Coding: 16711696 Shop #: WSC 00000 No fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0411602 Shop #: WSC 06435 000 00000 VCID: 45871E320C0FEA36E75-8010No fault code found.-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 009 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 30695FE6A38D5F9E243-8065No fault code found.-------------------------------------------------------------------------------Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 980 J HW: 8P0 920 980 J Component: KOMBIINSTR. VDO H25 0110 Revision: D06 Serial number: 2247CD06001010 Coding: 0005403 Shop #: WSC 00581 210 64475 VCID: 3E7571DE69D9B9EEA6F-806B1 Fault Found:00779 - Outside Air Temp Sensor (G17) 010 - Open or Short to Plus Freeze Frame: Fault Status: 00000011 Fault Priority: 7 Fault Frequency: 18 Reset counter: 148 Mileage: 163981 km Time Indication: 0 Date: 2013.04.02 Time: 16:58:46-------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0090 Revision: 08 Serial number: 2400103805E43F Coding: BD0F0340070101 Shop #: WSC 06435 000 00000 VCID: 2645B9BE9149012ECEF-8073No fault code found.-------------------------------------------------------------------------------Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 Component: HALDEX 4Motion 0101 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: EADD0D8EC5D1654EAA7-80BFNo fault code found.-------------------------------------------------------------------------------Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 980 J HW: 8P0 920 980 J Component: KOMBIINSTR. VDO H25 0110 Revision: D06 Serial number: AUX7Z0C7FNJ010 Shop #: WSC 00000 000 00000 VCID: 3E7571DE69D9B9EEA6F-806BNo fault code found.-------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 397F62C270F79ED693D-806CNo fault code found.-------------------------------------------------------------------------------Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K2 909 144 D Component: EPS_ZFLS Kl.10 1201 Shop #: WSC 00000 000 00000 VCID: 2D574692B4BF32760F5-80781 Fault Found:00778 - Steering Angle Sensor (G85) 000 - - - MIL ON Freeze Frame: Mileage: 3960 km Count: 1 Steering Angle: 0.00°-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 Component: KSG H02 0040 Coding: 198800186D288505485AC63000 Shop #: WSC 06435 000 00000 VCID: F9FF22C2B077DED653D-80AC Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Part No: 1K0 907 719 Component: Neigungssensor 002 0002 Subsystem 3 - Part No: 8P0 951 177 Component: Innenraumueberw.H03 00101 Fault Found:01134 - Alarm Horn (H12) 004 - No Signal/Communication-------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl Part No: 8P0 959 802 A Component: Tuersteuerger. H10 0010 Coding: 0000048 Shop #: WSC 06435 000 00000 VCID: 3A7D7DCE75F195CE9A7-806FNo fault code found.-------------------------------------------------------------------------------Address 56: Radio Labels: 8P0-035-1xx-56.lbl Part No SW: 8P0 035 195 HW: 8P0 035 195 Component: symphony II EU H54 0400 Revision: 18S Serial number: AUZ5Z4C5310279 Coding: 0000201 Shop #: WSC 06435 000 00000 VCID: EFEB1C9AFE338066FD9-80BANo fault code found.End ---------------------------------------------------------------------
    The g17 is the ambient air temp sensor clipped to the radiator cradle it gives you the temp on your cluster can't remember what side what was the cause of all the other codes ?
  1. Fascia for 2001 S3, any ideas where from?
    By pafitoui in forum In-Car Entertainment
    Last Post: 10th January 2004, 15:45
  2. lack of power. Any idea?
    By mattstead in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2003, 20:14
  3. Help - Any ideas on a noise?
    By mramage in forum Classic Audi Forum
    Last Post: 10th October 2003, 21:45
  4. My lumpy GTI, running lumpy, any ideas?
    By Dr_Lokos in forum General Chat
    Last Post: 26th August 2003, 22:32
  5. HELP any ideas?? PLEASE
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2003, 12:28
