Sky InsuranceJMB Retrofits
    Apr 2012
    London
    469
    Question A3 3.2 V6, problem with brakes when I slow down on 1st and 2nd gear! Any idea? Thanks
    Hi
    As the title says I've problem with disc brakes/calipers (not sure which one) but whenever I slow down to 1st or 2nd gear one of the two components seem to scream (not that loud though) but I could hear it very clearly!
    And it is very annoying, it happens only on stop and start, mostly 1st and 2nd gear!
    This might also help; it seem to scream louder when holding the clutch and about to shift!
    A3 3.2 v6 2004 with only 37k mileage (NOT many miles covers, so was just wondering what it could be)
    Also anybody knows what disc brakes/calipers are being used in 3.2 V6s? Is it the same as S3s, could I use the S3s!
    I was after some RS5 brakes and calipers, not sure if they would fit, if not what do you guys recommend?
    Does anybody knows how to measure a disc brakes to find out the remaining lifespan or what's the best way to tell if they need replcement!?
    Apr 2012
    London
    469
    Feb 2013
    Grimsby
    1,100
    S3 and 3.2 brakes are the same size
    05, A3 8P 2.0TFSI Quattro
  1. 1st and 2nd Gear problems after clutch change!
    By trophs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd October 2011, 21:26
  2. Problem with brakes.
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2008, 21:06
  3. Problem with brakes??
    By gjcknocker in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th November 2006, 14:02
  4. Help - Problem with brakes
    By imported_AndyB40 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th November 2005, 09:31
  5. Problem with brakes?
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2005, 16:36
Tags for this Thread
