Chris NottSky Insurance
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By N8
  • 1 Post By N8
Thread: ESP button not working after coilovers install - electronic damping delete solution?
    Sep 2013
    33
    Hi,
    Recently installed coilovers on my 2009 S3 that had electronic dampers (same as "Magnetic ride"?), there is now a yellow warning light on the dash in the shape of a shock absorber.
    Q1 - Is there any way to code out this warning with VCDS?
    Q2 - Does this kit work? -http://www.moddedeuros.com/products/kw-edc-cancellation-kit-68510144
    The ESP button does not work when pressed, I scanned it with VCDS and no related fault codes came up. I'm assuming it is to do with the electronic damping fault?
    Q3 - Is there another way to reactivate ESP button without fixing the electronic damping fault?
    TIA
    27,126
    You've replaced your mag ride or you have fitted an electronic system to a standard spring/shock car?
    Jan 2012
    478
    If you just swapped your mag ride for std coilovers then you may need to reconsider and buy the correct dampers for a mag ride car - why would you want to lose this useful feature?
    Nov 2011
    70
    I installed kw coilovers to my 2010 S3 that had magnetic ride fitted for original owner( I didn't like them) and I bought a delete kit from them that plugs into the original wiring harness and mounts to a small box you mount in the wheel arch. It prevents any warning lights coming on. I suppose you could buy this separately even if you don't have kw coilovers.
    Adrian
    Sep 2013
    33
    Replaced mag ride with aftermarket coilovers.
    Sep 2013
    33
    Quote Originally Posted by nluk100 View Post
    These aftermarket coilovers are the most cost-effective way to drop the car to the exact ride height I wanted. What correct dampers for mag ride car are you referring to? I assume they would be quite expensive.
    Sep 2013
    33
    Quote Originally Posted by AdriansS3 View Post
    Adrian
    Thanks. Is this the same delete kit that came with your KW coilovers? Home Page ES#2608438 Electronic Dampening Cancellation Kit - 68510144
    I don't have KW but will probably get these if the warning light cannot be coded through VCDS.
    Nov 2011
    70
    That looks like it yes. When my car went into an Audi specialist prior to me installing the delete kit they said they could not code it to stop the light coming on as without anything connected to the car wiring it was classed as an open circuit.
    27,126
    More than likely you could disable mag ride with vcds & disconnect the controller/switch.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    You should have bought KW DDC coils
    Sep 2013
    33
    Like AdriansS3 mentioned, have not yet heard anyone who was able to code/disable it through VCDS.
    Sep 2013
    33
    Quote Originally Posted by N8 View Post
    Not for 3 times the price. V3s are too expensive over here.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Your driving an S3 with mag ride, I'm sure you could have arranged something
    Sep 2013
    33
    I'm poor, bought the S3 used, V3 with EDC delete would have been almost 15% of what I paid for the car, can't really justify it.
  1. A4 rear speakers not working after stereo install.
    By burnzdog in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2012, 16:45
  2. unlock button on key fob not working after reconecting car battery
    By jonnyb289 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2012, 08:56
  3. Interior ultrasonics button not working?
    By reggieroo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th September 2011, 09:58
  4. Symphony buttons not working any ideas ?
    By bogard in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2010, 20:31
  5. SPORT button not working??
    By gjrquattro in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 4th October 2008, 13:24
