Chris NottSky Insurance
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By S3_Jacko
Thread: Fitting aftermarket TBE from 5 door to my 3 door, HELP.
    Nov 2013
    Suffolk
    47
    Add cnahamilton on Facebook
    Hi there, i am after some help please. Sorry if this has been asked before, but i cant find the answers im after.
    I have a 2007 s3 3door and found an exhaust for a 5 door. What will i need to do to make it fit?? Any suggestions would be great!! Chris
    Jan 2009
    125
    I bought a second hand milltek from VAG.com, apparently for a 3dr, the fit was sh1te so I put it into a garage to be cut and welded because the tail pipes stuck out far to much. I'm thinking it was originally from a 5 dr.
    S3 Revo Stage 2+
    Milltek Non Res-ITG-Autotech HPFP-Loba SMF
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    The only thing that I would have thought the difference was that the 5 door was longer?
    Personally if it was me in that situation, i'd get it on a lift and try a test fit... see if it would fit by cutting some pipes... set it on he mounting points and see where it doesnt fit and cut... i'd make it fit somehow....
    cnahamilton likes this.
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    Nov 2013
    Suffolk
    47
    This one does look as if the tail pipes will stick out quite a way! The main center section doesn't quite look right compared to a non resonated 3 door one. Looks like quite a lot of grief....
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Back box is relatively easy to get off with a jack under the car then you could measure it up i'd guess.... could you not cut them down and put new tips on it.... I would only go to all that work I suppose if the 5dr exhaust saved you a fortune
    Nov 2013
    Suffolk
    47
    Yeah it does save quite a lot tbh. Its 450.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    By the time you've paid to have it modified to fit you won't have saved much and gained a lot of hassle and potential for a poor fit.
    Nov 2013
    Suffolk
    47
    Quote Originally Posted by bmh.01 View Post
    i see what you are saying but it won't cost me anything to have it all modified, cut and welded etc. which is why I'm tempted with buying it. If it was going to cost me a lot to do I wouldn't bother with it and just pay extra for the correct one if you see what I mean.
    336
    From memory the downpipe and cat section is the same on the milltek 3dr and 5dr. Cat back has a different part number. My guess is that it is more likely the centre section that is longer, but you should be able to confirm by looking up all the different part numbers (assuming its a milltek). If that was the case chopping a couple of inches off in the middle shouldn't be too difficult.
    Nov 2013
    Suffolk
    47
    I have tried comparing them but sadly they are not the same make. Downpipe and cat does look a tad longer. Center section is longer and resonated and does not look anything like a 3 door non resonated section. So my guess is that is where most of my issues will lie...
  1. Anyone fitted aftermarket cruise control for A6?
    By StevoA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th September 2007, 12:07
  2. Anyone fitted the tailpipes from the accessory range?
    By dickys3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th March 2007, 22:18
  3. Fitting aftermarket seats to S3
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2006, 20:59
  4. Fitting aftermarket Stereo to A4
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2005, 17:37
  5. Fitting aftermarket stereo
    By NickRE2000 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2004, 11:58
