Chris NottMonster Motorsport
    Nov 2013
    S****horpe
    Airbag Light After Battery Disconnect
    Hello,
    I have disconnected my battery the other day to install a AMP. I tested it out I had the steering light and airbag one on. The steering went after driving for 10 secs. I can't remember if I put the battery back in after I put the connector on the back of the glove box. I have access to VAG-COM is it just a reset of the fault. And is it due to me connecting the battery up before the plug?
    Thanks in advance
    Aug 2006
    NI
    785
    yeah the keyswitch in the glovebox being disconnected is enough - just reset it.
    back to boost, oh how I missed thee....
  1. Red steering light and yellow esp light after battery was disconnected.
    By Conormalone in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2013, 09:48
  2. Audi A4 avant airbag light after headlight bulb change!
    By fabtdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2010, 07:14
  3. Re-setting ECU After Battery Disconnected?
    By Siena in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2008, 19:06
  4. Replies: 4
    Last Post: 21st January 2006, 17:00
  5. Airbag light after glovebox removal
    By Roswell in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2006, 14:12
