Chris NottMonster Motorsport
Results 1 to 7 of 7
    Jan 2012
    SW London
    794
    Changing front wishbone bushes
    Had a search can't really find much on the 8p side of things.
    Has anyone successfully changed the front wishbone bushes on the car themselves? I have powerflex versions for both front and rear bushes on the front wishbones. I dont have a ramp so it'll be done with the car on stands. I've got a wide selection of tools, and the guys opposite where i work have a hydraulic press but that depends on whether the wishbone comes off completely or not (depending on how easy or hard that is). Any pointers?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Easy enough to do just time consuming and a ****ty job as bushes always are, they will come out in a vice but a press makes it a lot easier.
    The problem you will find as that you won't be able to do them back up on the car without something to compress the rear console bush as the mountings will be half a hole out. I use a large f-clamp to compress them when refitting.
    Other than that they're easy peasy really. Just a matter of sticking with it.
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    447
    Just had both my front & rear bushes changed on my front wishbones.
    Cost two-three hours labour and a lot less hassle.
    Also, don't forget to have your wheel alignment checked/corrected after.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Aug 2013
    Lancashire
    43
    I spent a couple of hours messing around trying to remove mine before conceding and going to a garage to have mine changes. Charged me £50 plus parts.
    Jan 2012
    SW London
    794
    Quote Originally Posted by TwoFlatTyres View Post
    Seems reasonable. think i might just get some quotes. I like getting stuck in when it comes to things like this. Only way to properly learn
    VCDS User
    Jan 2012
    SW London
    794
    Quote Originally Posted by bmh.01 View Post
    Am i right in saying the subframe needs to be lowered? Would u able to give me a rough guide?
    VCDS User
    Aug 2013
    Lancashire
    43
    Quote Originally Posted by Sidhu88 View Post
    I should add, then I had the tracking done for about £40.
  1. Front wishbone bushes
    By Don's A3 TTu in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2011, 21:53
  2. Replies: 0
    Last Post: 23rd October 2010, 20:43
  3. Front wishbone bushes - A3 and S3 identical?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2007, 09:47
  4. Steering alignment/front wishbone bushes
    By Distant Sun in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2006, 13:43
  5. Front Wishbone Bushes
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2005, 09:13
