Chris NottMonster Motorsport
    Nov 2013
    Wheel bearing change
    One of my front wheel bearings is on the way out, the garage I phoned said that they change the whole unit and not just the bearing so no need to press any thing in which made me think, if there isn't any bearings to press in I could change the bearing my self. Is the garage right? Do you buy the whole hub and just change that?
    27,096
    Its a bolt of/on job, nothing to press in in the 8P, the previous 8L was pressed in.
    Nov 2013
    Is it quite easy to do?
  1. Wheel Bearing Change
    By B1GW1L in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2012, 10:52
  2. What sockets for DIY 8P front wheel bearing change ?
    By marty1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th October 2011, 19:16
  3. What sockets required for an Audi a3 wheel bearing change.
    Last Post: 6th October 2011, 09:25
  4. Changing Diff Oil & Rear Wheel Bearing
    By g60leigh in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 12:13
  5. changing my wheel bearing what specific tools do i need?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th September 2006, 18:36
