Volks AutosEM Tuning
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By LEE69
Thread: Coolant...
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Coolant...
    Hi all,
    So, after around a year and a half of owning my A3 (details in sig), my coolant light has just come up flashing on the DIS.
    Never had to top it up on previous cars but after some research, it seems that I can't be topping it up with a different coolant and mixing them. What coolant do I actually need to top it up? I've read it needs to be pink and G12 or G12++? Is there a Halfrauds alternative instead of going to the stealers?
    Also, I've just checked and the coolant that is currently in there is a dark colour rather than pink. Should I be concerned about this?
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    899
    Is the level ok? If so just scrape the prongs inside with an old toothbrush, mine did the same the other day now it's fixed.
    G12 G12+ and G13 can be mixed.If it isn't a red colour i'd be looking to get it flushed and changed.It could be dark red you could get the antifreeze level checked.
    Growing old is mandatory, growing up is optional
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Cheers for the quick reply dude.
    Checked level earlier and it has just dipped below the first low line so needs topping up. I did read about the sensors playing up though which is what must have happened on yours.
    When I finish work, I'll take the top off and see what colour it is. Just looked at the side of the bottle and it seemed quick dark rather than red/pink colour.
    What's the crack with flushing and changing it? Something that can be done by myself, or does it require a garage with specialist equipment?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    899
    Remove the rad hoses flush out with a hose and re-fill.
    NHN likes this.
    27,105
    As above, I would flush the system & use a 50/50 mix of audi's G12/G13 offerings & H20, I don't use Halfords at all, I carry a mixed bottle at all times, its not expensive tbh.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I got 2 bottles of g13 from Audi at the weekend. Was only £22.
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Had a look at colour of coolant this morning and its a dull greeny colour, might as well get it changed as that could be anything.
    To flush, is it just a case of doing what you've said Lee? I've read a lot of different methods stating that you need to drain, put hot water in bottle, let the engine run with the heating on etc. Is all that unnecessary?
    Also, how much of G12/13, if mixed 50:50, will I need?
    Thanks again
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,793
    you'll need 1x G13 to top up with.
    Part number: G013A8JM1, come in 1.5 litre bottles, with purple lid.
    Only need a couple of bottles in there I'd say if doing a full flush, the rest water.
    Otherwise I'd just topup your expansion bottle straight from G13 bottle.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    899
    Quote Originally Posted by leeds2592 View Post
    Thanks again
    Never used hot water just flushed it through with a hose, not sure of the capacity of the coolant sorry.Also need to get the ratio correct on the bottle
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    2 bottles of g13 and rest de ironised water
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Cheers for the replies lads, I'll get the proper stuff rather than the Halfords alternative for peace of mind.
    Few more quick questions, where do I drain it from? And, how do I make sure there's no air bubbles?
    Is it going to harm my engine running it with low coolant? It's not ridiculously, only just dipped below the low line but I won't be able to flush and get the new stuff in until the weekend and I use my car everyday to get to and from work (only around 10 miles).
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,793
    Top up with ordinary water, you'll have no troubles.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    dsc03321k.jpgBottom left of the picture at the bottom of the radiator is a hose, pull that off and flush with a hose as above. (aint got a photo of the exact hose)
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    899
    Nothing wrong with halfords coolant, i use it.
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Ok, so I topped it up with water to tick me over until I can flush it and get it replaced. Two days later its below the low line again and its flashing up on the DIS.
    Not had chance to check for leaks yet, but I hope it isn't the head thats given up the ghost
  1. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  2. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  3. S3 Coolant warning
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 21:02
  4. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
  5. Coolant pipes
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2004, 23:10
