Badger5Monster Motorsport
Like Tree2Likes
  • 1 Post By Vorshprungdork
  • 1 Post By 16Klappe
Thread: TDI 170, Exhaust fumes coming through heater-resolved.
    Feb 2004
    Borders, Scotland
    405
    Cool TDI 170, Exhaust fumes coming through heater-resolved.
    I never made a post about this but my Wife's 170 has had an exhaust fumes smell since we got it over a year ago.
    I did various searches on here and other forums and got loads of ideas what it might be. We were fairly sure it was exhaust fumes and it was coming though the heater but checking under the bonnet came up with nothing in particular that could be causing it. I had the under tray off and the exhaust and all pipes seemed fine, tried semi blocking the tail pipes to see if anything would come out towards the front but nothing.
    I read that the underside of the bonnet needed to seal to the bulkhead/inner wings, cleanerdall the seals,no rips of tears etc, changed the pollen filter, nothing.
    She was at the point of being so sick of it she was taking about trading it in, then I was on her doing my usual luinchtime browse at work and I was looking at pictures of Jardo's new A3 TDI, when suddenly it hit me, he has a seal all the way round the inner wings and our's stopped about 10 inches short at each side. I checked some other pictures and another car and sure enough our seal was short (WHY would anyone cut it or is it the wrong seal, probably never know?) anyway I got a bit of seal from a scrappies (Passat seems the same) and jointed it in - NO fumes
    Will buy a new seal now as it's obviously worth it, can't completely give Jardo credit but cheers mate anyway
    16Klappe likes this.
    c_w
    1,061
    Good you got it fixed - those seals do the job of protecting the air intake for the cabin as you've found! But I'd still be inclined to double check if there is a leak somewhere in the engine bay/exhaust as in theory there should be any fumes smell from here asuuming nothing is leaking.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Good spot! I hope it works.
    I'm so glad my detailed pictures have helped someone
    All the best.
    Vorshprungdork likes this.
    I quite often say I'm going to do things.
    Then never do them.
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    can I be a pain and ask what seals you are talking about here? I had the same problem the other night, I could smell like a warm oil fume smell, and I had to open all windows in the end!
    Feb 2004
    Borders, Scotland
    405
    The seals are the ones that go round the engine bay and seal the area when the bonnet is closed down onto them. There should be one across the bulkhead panel, with 2 foam blocks that is sits against, attached to the inner wings. Then one longer one that goes from the foam block at one side, all the way round the bay to the other foam block at the other side. It is this one that was about 10" short at both sides on mine )or 20" short in total, depending on how you look at it) allowing the fumes to come out and presumably up the inner wings above the seals and in the heater intake, under the windscreen.
    Totally agree with what C_W says above, there really shoudn't be that much fumes in the bay in the first place but there are a number of people that have had this problem and I couldn't find any leaks, will keep looking though
  1. Anyone had heater issues on tdi 170 SB ?
    By Baza1819 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2012, 18:37
  2. a4 tdi 170 straight through help!!!!
    By cookie 1984 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th October 2012, 08:05
  3. Prove that MY11 A3 2.0 TDI 170 comes with Twin exhaust pipes!
    By Diamond in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2010, 09:20
  4. 2.0 TDI 170 max torque through the clutch?
    By Lukeyb in forum Tuning
    Last Post: 28th December 2008, 01:23
  5. A3 TDI 170
    By Karcsi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2006, 21:14
