Monster MotorsportChris Nott
    Jan 2012
    1,633
    Electrical Problems
    Have had these faults for over a week now which will not clear.
    My Cruise still functions correctly and this is confirmed in the measuring blocks.
    Have checked all fuses I've found and they're all good.
    Rosstech doesn't really give much info on the descriptions either.
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Monday,02,December,2013,08:43:59:49196
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 56 62 72 77
    VIN: xxxxxxxxxxxxx
    Address 01: Engine Labels: 03G-906-021-BLS.clb
    Part No SW: 03G 906 056 S HW: 03G 906 021 AB
    Component: R4 1,9L EDC G000SG 2917
    Revision: --H09--- Serial number: xxxxxxxxxxxx
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    VCID: 37795312468DA8A6659-8062
    6 Faults Found:
    001384 - Cruise Control Switch (E45)
    P0568 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.87 V
    Bin. Bits: 00001100
    Bin. Bits: 11000000
    (no units): 0.0
    005785 - Powertrain Data Bus
    P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 134162 km
    Time Indication: 0
    Date: 2013.12.01
    Time: 00:00:45
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.79 V
    Bin. Bits: 00001100
    Bin. Bits: 00000000
    (no units): 0.0
    000000 - SAE - Reserved by Document ISO 15031-6
    P0000 - 001 - 2005 - Intermittent
    Freeze Frame:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 134162 km
    Time Indication: 0
    Date: 2013.12.01
    Time: 00:00:45
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.79 V
    Bin. Bits: 00001100
    Bin. Bits: 00000000
    (no units): 0.0
    005685 - Powertrain Data Bus
    P1635 - 000 - Missing Message from A/C Controller - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 6
    Reset counter: 255
    Mileage: 134162 km
    Time Indication: 0
    Date: 2013.12.01
    Time: 00:00:45
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.79 V
    Bin. Bits: 11001100
    Bin. Bits: 00000000
    (no units): 16.0
    005687 - Powertrain Data Bus
    P1637 - 000 - Missing Message from Electric Load Controller - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 134162 km
    Time Indication: 0
    Date: 2013.12.01
    Time: 00:00:46
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.40 V
    Bin. Bits: 11001100
    Torque: 0.0 Nm
    Bin. Bits: 00000100
    Readiness: 0 0 0 0 0
    Jan 2012
    1,633
    Anyone any ideas?
    Jan 2012
    1,633
    For anyone who's interested I managed to get rid of these.
    Missing message from steering ecu so before starting the autoscan I kept the cruise switch pushed up, started scan and no errors.
    Cleared all errors from applications, turned ignition off and on and rescanned not touching the cruise. All faults gone
  1. Electric problem - HEEELLLP!!
    By mordz in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2007, 20:33
  2. Electrical problem (Number plate lights)
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2006, 14:02
  3. Dreaded electrical problems!
    By Vorshprungdork in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2005, 20:34
  4. Electrical Problems
    By pmorgan in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th September 2005, 21:33
  5. ELECTRICAL PROBLEM ON A6 1.9 TDI 1998 >
    By imported_terry2wheels in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th August 2004, 19:29
