AH FabricationsBadger5
Results 1 to 9 of 9
    Nov 2013
    Cigarette lighter/charger problem
    Hi,cigarette lighter in my 2004 a3 has stopped working.have changed fuse and brought a new lighter unit.still not working.light comes on round it when headlights go on.have also checked charger leads in other cars.they work fine.anyone have anymore ideas??
    thanks
    chris
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Broken relay, wire or bad connector connection somewhere.
    Or perhaps the ECU has switched off the supply power.
    Nov 2013
    What relay would I need to check? Would the ecu do that if there was a problem?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    usually its just the fuse, you say you changed it but there are 2 fuse locations for the cig lighter. have a good look on the panel that covers the fuse box for the other location
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Jan 2012
    SW London
    794
    Quote Originally Posted by Ash187 View Post
    what he said. Make sure u check all the fuses properly.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Sportback owner
    Apr 2007
    France
    492
    Make sure you check F24 = 20A in the cabin fuse box. Other than that it may be that the cig lighter contacts inside the cig lighter unit are not making a good contact. They may have been bent.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Nov 2013
    Have checked 24 fuse in the panel by drivers door(and replaced) where else should I be looking?
    Sportback owner
    Apr 2007
    France
    492
    You will have to look very closely at the cig lighter itself, even if it is a new unit, to see if the contacts inside are making proper contact with your plug. I have found in the past that there are several mechanical (dimension) standards for cig lighters and sometimes the plugs just don't fit well enough. Had this problem with an LED torch that did not fit in properly, and would not charge. Perhaps you could try a voltmeter, and see if indeed there is any 12 volts showing up inside the cig lighter. If not it would point to a wiring problem (break, bad contact, disconnection etc). All I can think of. Good luck.
    Nov 2013
    Will have a look in the morning see if I can see anything obvious with the lighter itself.thanks all go the replies.
  1. About the Cigarette Lighter
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2007, 10:23
  2. Cigarette Lighter Died
    By pav-g in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2007, 14:34
  3. Cigarette lighter stopped working ? any ideas ?
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2007, 18:03
  4. Replies: 0
    Last Post: 28th June 2005, 14:19
  5. Cigarette lighter problems
    By Adie in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2003, 20:41
