JMB RetrofitsChris Nott
    Aug 2013
    Northampton
    ESP G201 Brake pressure sensor A3 53 2.0 TDI
    Hi Guys,
    I have a problem with my esp, from looking at other posts i can see its quite common, the fault code is the G201 Brake pressure sensor. I have had quite a few ppl look at it and have been told so many different things. I have paid on two occasions to get the lights taken off and had been told the problem was fixed only to have the ESP light come on a few days later.
    Can someone please let me know what the average cost is to get this sorted and if anyone in Northampton can have a look or carry out the work as im sick of getting ripped off. Also when i showed this to one of the Mechanics he had advised me that a new pump had been put in and the guy who sold it said the same but couldnt get the light taken off??
    27,110
    Depends on the code, does it need calibrating or is it actually showing a fault, get it scanned with vcds & post up the code/error from vcds.
  1. Where is oil pressure sensor on a 2.5 TDI
    By Turkster in forum Diesel forum
    Last Post: 6th July 2012, 19:12
  2. ESP fault code 01435 Brake Pressure Sensor - Common fault apparently
    By DenniS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 13:50
  3. Audi S4 brake pressure sensor problem, 01435.
    By antboo1.8t in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2011, 20:08
  4. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
  5. 01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
    By Jay.Ing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2009, 16:03
