Chris NottVolks Autos
Results 1 to 34 of 34
Like Tree6Likes
  • 1 Post By hollow
  • 1 Post By tdi-man
  • 1 Post By autolatry
  • 1 Post By Artimus
  • 2 Post By Biggles44
Thread: Injector issues
    Biggles44's Avatar
    Aug 2013
    60
    Injector issues
    Yet more problems with my pile of shyt.
    After having a new head and all the other stuff done after our cam belt going, the garage tells me we need new injectors at £300 a pop.
    Do the injectors get damaged when a cam belt goes on audi. The car is a a3 2007 2.0 tdi 170 bhp.
    this is the worst car I have ever owned and when it's fixed will be glad to see the back of it.
    Two wheels are better than 4 :-)
    Nov 2008
    389
    170 engines are covered under an injector recall. Audi will process the claim if you take it to them....
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Biggles44's Avatar
    Aug 2013
    60
    Injectors have already been done on a recall. My question is, do the injectors get damaged when the came belt goes ?
    Nov 2008
    389
    Apologies fella - didn't realise.
    No idea on the amount of damage that can occur - sorry.
    Biggles44's Avatar
    Aug 2013
    60
    That's ok, thanks anyway mate ;-)
    tdi-man's Avatar
    Jul 2009
    1,612
    if there not set up rite when putting the head on if there like the 140 injectors then yes they can broke when setting them up
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Biggles44's Avatar
    Aug 2013
    60
    Thanks for the reply.
    So who would be at fault regarding the injectors ?
    tdi-man's Avatar
    Jul 2009
    1,612
    not sure if the 170 inj get damaged when cam belt goes. you need to ask why they need replacing ?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    Injectors on eBay go for about £80
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Biggles44's Avatar
    Aug 2013
    60
    The problems continue. After cam belt going 3 weeks ago, had recon head fitted,new cam kit and all the other jazz. Got the car back, and when driving it's fine until you put your foot down and it starts missing. So back the the garage, and they said injector number 2 needed replacing, so they replaced that and the car was still missing, so they replaced the other three as they'd said it upset the balance. Continued missing, then they told me they were given the wrong injectors. So they replace injector 2 again with the right injector, and it's still the same. So I rang audi and they said the garage have no idea what there doing, so I'm going to collect the car from the garage tomorrow and take it to audi to see if they can source the problem.
    what a friggin joke this is turning out to be.
    car drove perfect until cam belt going, now it's all messed up.
    any one have any ideas what it could be ??
    Biggles44's Avatar
    Aug 2013
    60
    Anyone ?
    tdi-man's Avatar
    Jul 2009
    1,612
    where abouts r u
    tdi-man's Avatar
    Jul 2009
    1,612
    Biggles44's Avatar
    Aug 2013
    60
    Yeovil, Somerset. Not sure what to do about the garage that's worked on it, I haven't paid them yet as I'm sure they have created a problem. Taking to audi in the morning to get there opinion, hopefully
    tdi-man's Avatar
    Jul 2009
    1,612
    probs not set up correctly
    Aug 2013
    Surrey
    135
    I'm sure if the oil used is not correct then that can damage them and with it missing when you put your foot down sounds like a compression issue around your valves/springs.
    I have seen it on a merc with a recon head after revving it up a couple of the valves would stick open. Turns out incorrect valve springs were used,
    Biggles44's Avatar
    Aug 2013
    60
    Update.
    the garage that did the head and cam belt for me has now said they can't fix the above issues, so I have taken it away from them and taken it to audi, I have to now pay £200 for full diagnostic, they will then tell me what the issue is as nothing is showing up on audi computer.
    as I will have to pay audi to now fix it, would you pay the other garage any money for what they have done, as I now have a car that is pretty much un drivable
    May 2009
    south yorkshire
    628
    probably a valve not seating correctly
    Biggles44's Avatar
    Aug 2013
    60
    Audi are saying they think from the test drive that it's a injector issue. But would you pay the previous garage for what they'd have done ? Bearing in mind I'm having to pay for it to be fixed and a car that will hopefully work :-)
    May 2009
    south yorkshire
    628
    could be an injector issue ,even after a diagnostic if the injectors seem to be in spec ,unless they try a new set of injectors you'll still not know . audi won't try a new set unless you're paying for them first ,there not £300 each now there less than £200 each as so many have gone faulty.
    tbh audi only have as much chance as a good indy to correct the fault . probably even less as if guided fault finding doesn't come up with some answers then the techs there will be left scratching there heads.
    Biggles44's Avatar
    Aug 2013
    60
    Friggin nightmare this car, running out of money to keep chucking at it. Since I've owned it, it's been of the road for nearly half the time.
    should of got a ford ;-(
    May 2009
    south yorkshire
    628
    lol @ ford , don't go there you've just gone to the wrong people to sort it . a good indy garage would rectify the fault ,obviously not bothered about there reputation.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Any ideas as to how the injectors became damaged? Wtf is this they have to set up sh!t? Ive just slotted mine back where they came from with new seals on. Surely the ecu is still the same as before they were removed?
    Also you should pay the garage mate (providing they are just mechanics and they didn't sell you the car)
    May 2009
    south yorkshire
    628
    the injectors can be damaged and so can the bores where they sit , they have to be levelled when tightening bolts or it can damage the bore hole for the injector and the injector seal , also if the bolt for the rocker above the injector is tightened up too much ,it damages the internals of the injector .
    seen one only the other week in a caddy where the injector wasnt even tightened down properly ,damage was that bad the bore hole was left oval , cost of repair a new head .
    autolatry likes this.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Oh I see. I thought by set up it meant they needed 'programming' in something.
    Mine are held in place by the fuel rail so I would hope I've put them in correctly.
    tdi-man's Avatar
    Jul 2009
    1,612
    if it was me I wouldn't pay um a penny . they didn't fix the problem.
    Biggles44 likes this.
  28. #27
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
  29. #28
    Dec 2013
    142
    Injector issues
    Lol!
    You would think Audi would repair since it's been on recall already or cover most parts and labour costs with goodwill.
    Hope it all plans out.
  30. #29
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    Quote Originally Posted by Biggles44 View Post
    Update.
    They've washed their hands of it so they shouldn't be getting a penny from you. In all truth, If it turns out it's their doing, you should be taking Audi's final invoice to them for reimbursement.
    2009 A3 SB 2.0T DSG S line
  31. #30
    Biggles44's Avatar
    Aug 2013
    60
    New update.
    cars fixed
    The dick from the first garage messed up the injectors, used the stretch bolts twice or more, instead of once only, used the seals twice or more, some bolts were only done up just over hand tight,no bolts were torque tightened. Joker.
    so audi have fixed it at a cost of £436, there going to service the gearbox tomorrow for fixed price £149, feeling happy again and will be happy to get it back.
    To Audi
  32. #31
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Good news mate. If that's the case then fair play, don't pay the first garage anything.
    You going to keep it now?
  33. #32
    Biggles44's Avatar
    Aug 2013
    60
    It's our dream car to own, it's been off the road more than on, cost me a fortune to get fixed,but I love the look of it, and when it's on form it's the dogs nuts to drive.
    so I'm going to say yes I will keep it, and fingers crossed it won't let us down.
    Artimus and autolatry like this.
  34. #33
    Aug 2013
    Surrey
    135
    Good news. ! Glad it's sorted!
  35. #34
    Nov 2013
    Heath Hayes
    951
    Glad you have the car sorted the place you took it too first sounds like a load of cowboys. Very shoddy work no wonder it wasn't running correctly.
    Karl.
  1. BKD - Possible Injector issue?
    By Cyrix in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2013, 18:10
  2. Possible injector issues?
    By Gourlay1990 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2013, 05:04
  3. K04 turbo and fuel injector issue
    By s3black in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2012, 09:42
  4. Replies: 6
    Last Post: 2nd May 2012, 20:52
  5. possible injector issues, any help very much appreciated!!!! a4 tdi 140 bhp
    By chrisk1700 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th April 2012, 21:34
