JMB RetrofitsVolks Autos
    Aug 2013
    10
    Battery drain - please help
    My 2.0 fsi clock keeps resetting and the radio goes into safe mode, it starts up completely fine and the trip computer stays the same, and even the track number on the cd player stays the same once the code has been put in.
    I've checked the battery terminals and seems fine, am going to get the battery tested just in case but I'm confused why it would start so easily if that was the problem.
    When I bought it the cigarette lighter looked to be water damaged and the fuse was blown, changed the fuse and it works now but could there be a strange kind of electrical link?
    Only other thing I can think of is there might be a bent prong on the instrument cluster which was sent off to fix the rev counter a couple of months ago? Again looks fine but I've got an untrained eye!
    Any ideas or advice would be very welcome thanks in advance
    Aug 2013
    10
    I took it for the battery to be tested, nothing wrong with it but there is a drain on it somewhere. Even pulled the fuse out for the cigarette lighter and that didnt change it.
    Not really sure how to proceed would really appreciate some ideas
  1. Clock resets/changes
    By leegsi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd November 2013, 17:56
  2. Time keeps resetting on A3 clocks...???
    By xs2man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2010, 13:21
  3. Clock & Date Resetting Itself!
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2008, 23:19
  4. Dash clocks reset
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2006, 16:04
  5. MOVED: DIS, Clock, etc reset itself again A3 (8P)
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2004, 22:44
