Results 1 to 16 of 16
Like Tree5Likes
  • 2 Post By desertstorm
  • 2 Post By JimmyH
  • 1 Post By Sevv
Thread: Do disc heat shields need to be there?
    Sep 2013
    11
    My disc heat shields need replacing but I was wondering if they are really needed at all. If I just removed them would it make any real difference to the cars braking performance?
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Leave it alone, it's there for a reason. it prevents water, debris and general crap from damaging and contaminating the brakes.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,785
    Quote Originally Posted by Newquaygreen View Post
    The other side of Jimmy's comment is that mine have been removed a long time ago.....no issues at all.
    Jul 2013
    302
    its main purpose to my knowledge is a stone guard to stop stones being flicked up and getting wedged between then pad and disk ruining you lovely expensive disks , unlikely to happen but still
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,612
    Infact they are just a stone collecter!!
    Stones wedge behind the disc and this guard and block up the vents of the disc anyway, and cause horrendous noise.
    If you take them off, leave them off I say.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    I can safely say I have never had the issue of the disc guard collecting stones on any of my cars!?!
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    Not ultimately necessary, remove if you will. A lot of cars don't have them at all.
    Nov 2013
    Heath Hayes
    636
    On ETKA they are described as splash shields so the manufacturer puts them there to try and keep water from the brakes.
    If they didn't do anything then the manufacturer wouldn't put them there. I did remove them on my Passat when I upgraded the brakes to larger discs and never noticed any real difference except occasionally in the winter when there was a lot of slush around and the brakes were cold there would be a bit of a delay before they started working. Possibly due to the whole braking system being waterlogged.
    karl.
    Artimus and JimmyH like this.
    Mar 2012
    295
    My front ones have mostly rusted away anyway
    Pushing the limits..
    Jan 2011
    Australia
    1,224
    Add Sevv on Facebook
    i have taken them off and they are staying off and never had any problems, only thing is your more likely to get more brake dust.. bonus side is one less item bolted to the car and less weight (even though they arent heavy but still)
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Quote Originally Posted by Sevv View Post
    total weight saving of about 600 grams, personally don't think it's worth it .... Better option that'll save you more weight is go to the toilet before you go for a drive
    Sevv and CHEZ like this.
    Jan 2011
    Australia
    1,224
    Quote Originally Posted by JimmyH View Post
    lol, that must be one hell of a visit to the toilet haha, but if you think about it you can go to the toilet and loose the shields and you'll have extra weight of the car :P
    JimmyH likes this.
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Haha, mega toilet visit.
    boost-addict's Avatar
    Aug 2011
    977
    I had no choice all 3 bolts both sides snapped and haven't had rear guards on for some time. No adverse effects yet
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    Don't they also minimise heat soak from the disks into the brake lines, helping to avoid boiling brake fluid\brake fade on track days\spirited drives?
    2009 A3 SB 2.0T DSG S line
    Nov 2013
    Heath Hayes
    636
    Sometimes they will provide protection to ABS sensors and the like from direct radiated heat. On the Passat , when I removed the front shileds I cut a small piece of aluminium and secured it to one of the bolts to stop any issues.
    Karl.
  1. A3 S-Line Rear Disc Heat Shields?
    By Newquaygreen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2013, 18:34
  2. Coolant pipe with heat shield
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2008, 21:33
  3. heat shield for coolant pipe >?
    Last Post: 2nd August 2008, 18:56
  4. heat shield problems 1999 S3
    By ollyste in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2006, 23:19
  5. Anyone with a cone filter fitted or made a heat shield??
    By technics100 in forum Diesel forum
    Last Post: 17th January 2006, 22:29
