Sky InsuranceChris Nott
    May 2013
    Scotland
    Timing Belt tips
    So i'm fitting a timing belt kit and water pump tomorrow, its a 55 plate a3 TDI sportback. Anyone got any tips to help me on my way?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Did you get a new tensioner as well?
    One tip is to get a marker pen to mark up where the pulleys are in relation to each other so that when the new belt goes back on you can see if everything lines up and nothing has moved.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    If you need to, go to Specsavers first....
    May 2013
    Scotland
    Quote Originally Posted by RobinA3 View Post
    Yeah, got the belt, two idlers, tensioner and water pump.
    I've got the cam locking tools so i think i've got it covered. Just wondering if anyone had managed to make the job easier.
    Lewis583's Avatar
    Mar 2010
    872
    The offside engine mount bracket can be a pain in the arse to get out, so takes a bit of fiddling.
    The correct way of doing it is to lock the cams in place with a pin in each pulley and to then slack the 3 bolts on each pulley. This allows the cam sprocket to turn while keeping the cam in the correct position. This is to allow an even spread of tension on the belt when tensioning. The 3 bolts are then re-tightened.
    Otherwise you can get away with the old tippex method, just makes sure the belt is taught between the pulleys on the non-tension side.
    Everything else is pretty straight forward and remember, if there is new bolts/studs in the kit USE THEM!
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. broken timing belt on 1.9 tdi 90
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st June 2004, 12:14
  2. timing belt issue
    By hdailey in forum TT/TT-S/TT-RS Forum
    Last Post: 12th February 2004, 22:07
  3. S4 Timing Belt Prices
    By s4harv in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2003, 15:13
  4. Timing Belt Question from a newcomer
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 17:24
  5. 2.8 Timing Belt or timing Chain ????
    Last Post: 20th October 2003, 07:10
