Volks AutosChris Nott
Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By S3Alex
  • 1 Post By s3_sid
Thread: sachs organic clutch juddering
    Jun 2013
    104
    Ive only done about 800 mile since i was fitted but i am getting bad juddering in reverse and sometimes in first. Has this happened to anyone else cheers
    Keane's Avatar
    Jul 2013
    171
    Did you replace the flywheel ?
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    382
    I've fitted 2 of these kits on my previous tfsi cars.
    The first one juddered for about 500 miles and the second kit was the superseded part number which was much harder and juddered for about 1000 miles.
    As above if its on to your old flywheel it will take the 1000 miles to bed in.
    IBIS WHITE S3
    Revo stage 1, Loba Hpfp
    Jun 2013
    104
    new flywheel fitted oem luk one
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    382
    With a new clutch you'll be being extra gentle with it too?
    Sachs are very good and I'd say it'll bed in.
    IBIS WHITE S3
    Jun 2013
    104
    Quote Originally Posted by Marshy View Post
    Took it easy mate yeah, its vibrating really bad in reverse, I am sick of the car its been nothing but trouble and i got it from approved audi.
    Mar 2012
    296
    I know this probably doesn't help, but my 1.6 FSI has had a juddering clutch - especially in reverse for the 2 years and 20k I've owned it. I asked on here and apparently, it's normal.
    Jun 2013
    104
    Quote Originally Posted by JohnE View Post
    Its defo not normal it should not do that, mine makes some weird noise as well like rattling. Ive got brake judder and judder changing down gears so going to get all the mounts checked.
    Jul 2013
    302
    i got a loba smf and sachs clutch and im 2k miles in and its still judders the pedal is not quite has hard as it used to be but still a pin to do maneuvers as you just end up slipping the clutch , not overly impressed with it especially when its like £950 of clutch kit
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by s3_sid View Post
    I would say something's definitely wrong then, because mines fine (loba/sach) and been fine since day 1. Now about 10k on the clutch and it feels like new still.
    Jul 2013
    302
    Ever since install its judderd like mad getting better though , I may email loba and see what they say
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Along with that email, I'd be back in touch with the garage that fitted it.
    Jul 2013
    302
    Well to be honest mate I fit it my self , fit many clutches before rebuilt countless engines so I know its fitted correctly , unless they have daft fitting instructions but it dident come with anything
    Oct 2012
    171
    Could be contaminated clutch plate or flywheel..
    Jul 2013
    302
    It was all brake and clutch cleaners off to remove the grease ect
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    As you've fitted it yourself,I'd say that's the best idea,and they usually are very helpful and supportive with their products.
    Jul 2013
    302
    Yeah I have emailed them Alex I mean I have seen clutches of a bad batch of friction material judder a lot , its a lot better than it was but you would have expected it to have gone by now
    S3Alex likes this.
    Oct 2012
    171
    Let us know what loba say, hope you get it sorted.
    Jul 2013
    302
    Yeah I will do , I have a feeling I know they will say! They will probably say it installer error as I don't have a receipt for the install of it
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    382
    I'd still say it will improve with miles.
    As long as when you tightened the clutch cover you done it evenly that's the only mistake people make.
    IBIS WHITE S3
    Jul 2013
    302
    I would say it was fairly even I mean I didn't torque it up
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    382
    It used to be common for people to air gun them up rather them evenly tighten them which caused judder.
    I still think it's not fully bedded in and with the clutch material being so hard for purpose it's taking a while.
    You've done the easy 500 miles it says now try giving it some abuse to help it along.
    IBIS WHITE S3
    Jul 2013
    302
    Yeah I mean i did use the snap on buzz gun to get it nipped up but it was even as it was almost flat ! And it was even within reason as u checked with a ratchet , well I have given it a hard drive out the other day and it got a lot lighter pedal and and lot less juddery !
    But yeah I was carful on bed in , bar it stinking to high heaven when reversing and setting off occasionally I just pooled around town and say motorway miles granny shifting to hell !
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Ahhhhh well in that case, like you've already done then. Be interesting to see what they say. I'm just glad it hasn't happened to me because I imagine it'd be almost impossible to sell (selling mine currently) without reducing the price dramatically. Good luck, hope everything works out.
  1. sachs organic clutch and oem flywheel fitted s3
    By whitex8p in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2013, 19:06
  2. audi s3 sachs organic clutch
    Last Post: 26th September 2013, 16:22
  3. Audi S3 Sachs organic clutch and cover plate
    By Lizard-Racing in forum For Sale/Wanted - Audi Parts
    Last Post: 8th January 2012, 18:14
  4. A question for Sachs organic performance clutch users on the S3.
    By CJ3BLUE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2010, 22:43
  5. Clutch judder, only done 25k
    By jbreedon in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2004, 03:03
