Results 1 to 12 of 12
    Nov 2013
    36
    Car not starting, please shed some light!
    ​Car will run completely fine until it gets to engine temperature.. When it does it doesn't start again if you turn it off and on. I've had the cam sensor and coolant temperature sensor done as i was advised to but nothing has changed. (Car also is a little shaky on idle?)
    Nov 2013
    36
    Car is audi a3 2.0 fsi 2004
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    678
    Crank shaft position sensor would be my bet.
    Famous symptoms if them failing is they won't start when hot but will usually start if left 1/2 an hour.
    IBIS WHITE S3
    Revo stage 2+ and loving it
    Nov 2013
    36
    Quote Originally Posted by Marshy View Post
    have you had this? Wouldn't the crank sensor come up when diagnostic tested? The cam sensors keeps coming up on diagnostic and has been replaced twice
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    678
    The crank sensor when failing doesn't usually throw a code it gives a corrupt signal which usually condemns the cam sensor saying its signal is incorrect.
    Either that or your timing is wrong?
    Has it had a timing belt replaced recently?
    IBIS WHITE S3
    Nov 2013
    36
    oh so that would explain why the cam sensor keeps coming up. The guy i bought the car off said he had it replaced but he'd lost the receipt.. Just hoping it's not an ECU problem which'll cost a lot. The car is at an audi specialist now so they should be able to tell me whats wrong pretty promptly i guess.
    Sep 2013
    31
    Did you manage to fix the problem leeseager only my 2.0 fsi showing same symptoms any help would be much appreciated. Thanks
    Sep 2013
    31
    Sorry forgot to say ive changed engine temp sensor and engine speed sensor, changing the ess has much improved idling and general feel of the car but still tempremental on warm/ hot starting.
    Nov 2013
    36
    Quote Originally Posted by a3-205gti View Post
    i haven't had any luck yet mate, sucks. Nobody on here seems to know what it is.
    Sep 2013
    31
    Nightmare, took mine to audi sheffield sheffield who wanted £800, was going to pay until they said they couldnt gaurantee it would fix it lol, that nhn guy seems to know his stuff and hes mentioned on other threads it could be battery or starter so there my next things to change, might have to wait till after christmas tho. Good luck
    Nov 2013
    36
    Best thing to do would be to switch parts with a car thats exactly the same.
    Sep 2013
    31
    No mate sheffield.
  1. HELP!!!! Car Not Starting After Coil Pack failure
    By C39KER in forum TT/TT-S/TT-RS Forum
    Last Post: 30th May 2013, 22:22
  2. Car not starting, Help please guys.
    By chris-edin in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2011, 10:34
  3. first post: car presentation and need help
    By cba3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2010, 13:54
  4. car not starting
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2008, 15:14
  5. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
